When i go over bumps i hear noises under my car that sounds like a crackling or metal hitting something, its almost like a popping sound...any ideas?
Since it's bump related, it can also simply be loose end links. They take 7.2 seconds to check (do it with the car flat on the ground).
Good luck.
How do u check this...suspension stuff is not me...
Could also be the smog pipe hitting the exhaust. It is a long shot by the sounds you are describing, but it is wirth a look, and only takes 4.2 seconds to check.[/QUOTE
Ok ill take a look..is this the pipe that goes from the smog pump to the h pipe? im not to sure on this one neither....thanks man!
Check your balljoints out, too. Toss the front end on some jackstands and grab the tire at the top and bottom and see if it rocks. You should put the jackstands under the control arms to simulate suspension loading. If the tire deflects, you're probably looking at a balljoint replacement and picking up some 03-04 Cobra control arms with new balljoints already pressed in (plus new bushings) wouldn't be a bad idea.
Yeah smog pump to the passenger side of the h-pipe.
When I go over bumps I hear noises under my car that sounds like a crackling or metal hitting something, its almost like a popping sound...any ideas?
