So Embarassing ... [pics]
PULMEOVR
I need a bigger E-Penis.
Sep 29, 2003
560
Ottawa, Ontario Canada
So I got a flat tire about two weeks ago, and I've been riding on the spare tire since. I was waiting for a new set of Nitto 555s to come in (ordered them June 6th) so I could mount those up since my stock tires (at 38,000 miles) are worn out. For those of you who have never driven on your spare tire in your Mustang ... count your lucky stars!! It's embarassing and looks so stupid. Check out the pictures:
One of the bald stock tires:
The donut spare:
From the back:
New Nitto 555s (installing all four):
On a side note, riding on the donut spare makes your car feel like it has 500hp. Just tap the gas and the tire squeals so easily. Not that I tried or anything, but it sure caught me off guard once or twice!
Matt :eek: :canada: :flag:
Stock Tire - 245/45R17
Section Width: 9.64 in 245 mm
Rim Diameter: 17 in 431.8 mm
Rim Width Range: 7.5 - 9 in .
Overall Diameter: 25.68 in 652.27 mm
Sidewall Height: 4.34 in 110.23 mm
Radius: 12.84 in 326.13 mm
Circumference: 80.67 in 2049.0 mm
Revs per Mile: 809.9
Tire 1 - 145/80R16
Section Width: 5.70 in 145 mm
Rim Diameter: 16 in 406.4 mm
Rim Width Range: Unrecognized tire size
Overall Diameter: 25.13 in 638.30 mm
Sidewall Height: 4.56 in 115.82 mm
Radius: 12.56 in 319.02 mm
Circumference: 78.94 in 2005.0 mm
Revs per Mile: 827.6
Actual Speed: 60 mph 100 km/h
Speedometer1: 61.3 mph 102. km/h
Speedometer Difference: - Speedometer Difference: 2.185% too fast
Diameter Difference: - Diameter Difference: 2.15%
as you can see it is shorter:D
Well according to a tire size calculator on the net, the donut spare is shorter in diameter than the stock tire size. My donut spare (that came with the car from Ford) is a 125/90/15. Pretty tiny looking tire. It's 1.82 inches shorter than a stock tire. But, I'm not worried. I needed a t-lock rebuild anyways. Even before the spare was put on, sometimes I would only spin one tire in the rain. Makes me wonder why the t-lock is shot though, since I rarely spin the tires.
When I went out with my buddy tonight to finish off the tires, I did two very short burnouts and during one of the burnouts, both tires spun, then the driver side stopped (which was where the spare tire was). I shifted to second and again only the passenger side spun.
Soooo ... anyone know how much a t-lock rebuild goes for anyways? At the dealer of course.
Superstang, I've only been down to Kingston once. If you come down to Ottawa, shoot me a PM and we can meet up!
Matt :nice:
Swap the spare to the front if you aren't getting new tires anytime soon.
That's not that embarrassing. You got a flat..it happens.
I willingly drove around for two weeks with 4 15" V6 wheels with no centercaps while i took my stock wheels off to go put tires on (i refuse to bring the car due to a prior "incident"). People actually thought I wanted the car that way
V6 rims/tires aren't too bad.
I put my Nittos on this morning and the car drives better now. I still need a t-lok rebuild, PCV valve, and brake pads though. Everything always seems to go at once.
