So let me get thsi straight.............
nito88stang
2,012
Fullerton, California
If I use ARP headbolts along with their moly lube and thread sealer i ONLY have to torque those bad boys down to 60 lbs????
I did that last nite and I understand you get different torque readings but i guess i'm just uneasy about leaving it at 60. Although 60 with moly lube did feel like 85 with 30w motor oil.
BTW TrickFlow TW heads, 7/16 ARP head bolts, 302 block
If you have aluminum heads, you are reading the ARP instructions correctly. The aluminum heads don't need as much torque as cast iron because they expand more than cast iron. The moly lube significantly reduces friction in the threads which means less torque produces the same clamping force. Mine were torqued to 60-65 ft-lbs 2 years and 12K miles ago. No problems.
