so many switches eh
  • Thread starter Thread starter Euphoric306
  • Start date Start date Aug 3, 2005
Euphoric306
905
  • Aug 3, 2005
ok, when i was pulling my tranny (T5 STD), i was kinda confused about all the electrical connections coming off.
i know which one the speedometer cable is.. the big one with the gear on it, duh
wuts the one with two little prongs right off the tranny side on drivers side about mid-tranny?
and the one up by where the shift forks are is the reverse light switch im assuming?
its got me confused because the way i see it there should only be a speedo connection and a reverse light connection.. a neutral safety switch doesnt make sense because u can start the car in gear, as long as the clutch is depressed, which is sensed by a plunger at the clutch pedal, far from the tranny itself... is there one more thing i could be missing?
thanks for your knowledge
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 3, 2005
  • Aug 3, 2005
The two prong switch is the back up light switch.
The one up by the shifter forks is the neutral safety switch. One of the things it does is to tell the computer the trans is in neutral. If it isn't connected or working, you can't get the computer to dump the running codes.
Euphoric306
905
  • Aug 3, 2005
oooohhhhh.. that makes perfect sense
it didnt occur to me it could be a neutral safety switch that doesnt have to do with the starting circuit... gracias senor
P
What are these connectors
  • Papes
  • Jan 2, 2025
Fox 5.0 Mustang Tech Jan 4, 2025
General karthief
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
J
Transmission issues 4r70w
  • Jess!08249
  • Nov 12, 2024
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2024
