So, My '2008' arrives in 3 weeks... Strut tower Brace?
TheVin
47
Turns out the mustang I ordered will be a 2008- not that that means anything, as 2008 is a carry over year. Perhaps some 'debugging/Fine Tuning' to the components, but nothing different.
So, It looks like I'll have a few hundred after down payment to spare. I'm really anxious to get my hands dirty and start tweaking it, but its going to be awhile before I can afford the Roush full Suspension I want to put in... But, a strut tower brace is not included in the roush suspension kit, and it looks like it would take me all of 30min to 2hrs to put it in.
So I was thinking about ordering a strut tower brace from Steeda and putting it in myself. The questions I have for the community are:
1) Even though this is a straight-up no-jack bolt on a retarded monkey could do- should I have my dealer do it to avoid any warranty bitching?
2) Is it even worth the extra weight/money? IE, will it reduce under-steer or add significant stiffness to the chassis?
3) Am I under-estimating the difficulty in putting it in? Any alignment issues, any problems?
Steeda has a bolt-on rear frame brace, and also a rear strut tower for sale- both of those look within my skill level and also within my budget. So questions 1,2 and 3 apply to those as well. The alternative to either of the tower braces or the frame brace is to just sit pretty and continue saving up fro the Roush stage-2/3 suspension pack- which I will be having the dealer put on to forestall an debates over warranty coverage.
Vin
Coming soon:
'2008' black GT
All the interior upgrades w/beige leather
Shaker 1000
No mods yet, but fingers are already itching.....
i have the strange development STB, and its a great unit. it is super lightweight because it is aluminum. shipping weight was only 3 lbs.!! it looks great too with its polished finish. check them out at http://www.strangedevelopment.com/
as far as the handling.... you dont really notice a big difference at first. but once you have driven the car with the brace and then take the brace off, you notice a big difference, IMO. i would recommend a strut tower brace to anyone that drives their car like it was supposed to be driven.
the installation is just as simple as removing the nuts, and installing the brace.
Thanks Bigcat. Any Point in looking up the torque specs and using a torque wrench, or just give it a good snug with a quality tool? When I used to work on bikes, I always just snugged non-engine parts by hand and checked back in a few hundred miles to see. Can I get away with such lazyness on modern cars? :)
Oh- and I tend to drive the hell out of cars, so it will be driven to its limit... :nice:
DL
I would use the torque wrench on the STB. My muffler clamps...NOPE!!
I rebuilt my motorcycle about 2 years ago(bent frame). Basicaly did a complete rebuild with a donor frame. I used the torque wrench on just about everything that would turn. Figured if it was me and only 2 wheels beneath me, I was going to do everything by the book. Going down the interstate at 70-80 MPH and have an "uh oh" isn't going to be pretty on a bike.
I too, am one day planning on dropping in the Stage 3 setup as well:D
DL
the torque spec is 26 lb-ft. with the stock strut mounts. i have the J&M mounts, and they recommended 35lb-ft. because they have larger studs than the factory mounts. when i torque the STB, snug with a 3/8" hand ratchet is close to the 26lb-ft. factory racting. usually, i get less than 1/8 rotation before it clicks the torque wrench.
check out the link in my sig on how to install the STB. its the oldest write up i have, so its not laid out quite as well as my others, but i plan on redoing that write up so it flows as well as the rest in the near future. good luck! :nice:
Kooldawg:
Thanks, and yeah- you are right about people-versus-pavement... :)
Bigcat:
Thanks and I will certainly check that out. I did visit the Strange Development site and noted that their strut tower brace was significantly cheaper (and also that they have a rear tower brace that does not require welding!). I might still go with the Roush unit just because most everything else I am planning will be Roush- mainly because my Dealer is a 'Roush Dealer' and they would have a hard time doing the warranty dance with me if I installed the very parts they are supposed to vend and stand behind. However, at almost half the cost, thats something to think about!
One other (related) question Bigcat: I have not talked to my insurance agent about modification yet- do you (or anyone else, do chime in!) know if insurance companies deny or reduce payouts to 'bolt on' modified cars? I know I won't see the value of my upgrades returned on a total unless I buy 'gap insurance', thats not the question.
Vin
unless you specify in your policy to cover additional items, only stock replacement parts are usually covered. now, if it was just a set of taillights or something simple like that, they will usually just cover it. if it is a 10,000 custom paint job, you are out of luck unless its in the policy before the incident occured.
