  • 2.3L (N/A & Turbo) Tech
Solenoid
  • Thread starter Thread starter SVOconvLX85
  • Start date Start date Jun 8, 2004
SVOconvLX85
251
Vegas, for a while...
Jun 8, 2004
  • Jun 8, 2004
Would I be able to use the boost control solenoid from an '88 turbo coupe on my '85 SVO. If so, which side does the red wire go to and so on with the yellow wire?
351wcoupe
1,811
Manhattan, Kansas
Jun 8, 2004
  • Jun 8, 2004
yeah probably. The stock boost control solenoid scares me because I used to get alot of fluctuation until I switched to the mechanical ric gillis.
89lx2.3
316
Hagerstown, MD
Jun 8, 2004
  • Jun 8, 2004
hey 351W, i finally got my project running right. I ran the stock BCS for a while and as you mention got some spikes and other silliness (usually would spike up to 15 then settle down at 10, give or take) ... switched to a gillis and the boost control is great but seems like it spools slightly slower than it used to... you ever have any issues like that... how can you make these things spool faster, besides switching turbos that is?
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
M
Bad PCM?
  • MrPuffels
  • Jul 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 22, 2026
MrPuffels
M
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Electrical 91 hatch wiring help needed
  • FastDriver
  • Apr 7, 2026
Fox 5.0 Mustang Tech Apr 8, 2026
FastDriver
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
