I'm wondering what peoples opinions on the aftermarket solid steering shafts are. I'd provably go with a Maximum Motorsports unit if I was going to pay for one that was already made. Are these things worth the cash ?
The other thing is, these pieces look like they are stock shafts with a specific u-joint welded onto the end. I don't think it would be all that hard to replace the rag joint on a stock shaft with a u-joint as long I you could find one with the right end. It would simply be a matter of cuting the shaft at the right spot and welding on the new piece. Since the stock shaft is colapsable anyways, if you ended up a 1/4" too long you could just take up the extra slack by pushing the shaft into the colapsable section or even hacking off the difference at the other end to even it out. I suppose the only other issue would be making sure that the u-joing that connects to the rack is aligned properly so that my steering wheel is straight (this is provably the hardest part).
I was actually thinking of ebaying a shaft, looks like I could get one including shiping for under 50 bux. If I could modify another shaft I could install it when ready and minimize down time to the amount of time it takes to swap the shafts out.
