  • SN95 4.6L Mustang Tech
solid trans mount potentially bad?
  • Thread starter Thread starter chevyboy_z28
  • Start date Start date Apr 21, 2005
chevyboy_z28
66
Wixom, MI
Apr 21, 2005
  • Apr 21, 2005
ok heres the deal, after swapping trannys i had to have a mount fabricated b/c the mounting location on the trans didnt line up with the crossmember. the custom piece came out great (solid steel) and has been doing fine the past couple days ive driven the car, but my brother in law (ASE certified in everything under the sun) seems to think that the mount will be harmful to the trans, and possibly the driveshaft/u-joints. he says that theres nothing there to absorb the torsional vibration from the engine like the stock rubber one did, and thinks a cracked bellhousing or hundereds of u-joints and twisted driveshafts are in my future if i keep this solid mount. i told him that i respected his knowledge, but if this were true then they wouldnt make poly trans mounts, b/c theyre basically the same thing (solid mount with polyurethane covering). he says if anything i should get soild motor mounts to cut down on the torsion/motor torquing side to side and maybe ill be ok. i agree that they would help, but i just replaced the motor mounts last year when i put the headers on ($120...i wanna get my moneys worth!). what do you guys think, i had a solid/poly mount on my lt1 camaro and didnt have any problems however it was an automatic if that makes any difference?
mustang70
2,445
San Diego
Apr 21, 2005
  • Apr 21, 2005
Your brother in law is right. With a solid tranny mount and rubber motor mounts you can break the tailshaft housing or the bellhousing. The poly mount does have some cushioning built in for movement.
chevyboy_z28
66
Wixom, MI
Apr 21, 2005
  • Apr 21, 2005
would i be ok if i switched to poly motor mounts, or should i just go back, and have them integrate a poly mount into the piece they made?
chevyboy_z28
66
Wixom, MI
Apr 21, 2005
  • Apr 21, 2005
by the way does energy suspension carry poly motor mounts for us yet, because i had a bad experience with prothane.
chevyboy_z28
66
Wixom, MI
Apr 22, 2005
  • Apr 22, 2005
ttt
chevyboy_z28
66
Wixom, MI
Apr 22, 2005
  • Apr 22, 2005
anybody
chevyboy_z28
66
Wixom, MI
Apr 27, 2005
  • Apr 27, 2005
ttt
rkutzner
57
Westminster, MD
Jul 9, 2005
  • Jul 9, 2005
What was your bad experience with Prothane?
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Jul 9, 2005
  • Jul 9, 2005
He is 100% right.
The thing is poly mounts is you are supposed to replace all three together. That way vibration is limited, but not eliminated all together. Some guys do all three mounts solid, but i wouldn' recommend that on a street car.
But a soild trans mount with factory engine mounts puts a lot of stress on the bellhousing and tailhousing.
PS. I am a Mech. Engineer if that helps give what i say any weight.
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Y
2004 Mustang GT AUTO (4R70W) Grinding noise when going in R or Drive does it as I put it into park too
  • yellowandblack
  • Dec 12, 2024
1996 - 2004 SN95 Mustang -General/Talk- Dec 21, 2024
89ripper
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
