Some 3g Alt problem
Hey guys. So I finished up the install of a 3G alternator on my 82 Capri a couple of weeks ago. I tested it a few hundred times afterwards, just to make my car wasn't gonna go up in flames. Through the install, I researched and researched untl I was comfortable enough to hook it all up.
The today, I decided to check again. I am reading 12.2V on the battery,KOEO, KOER and at 1500 and 2500 RPM. And when I crank it over the battery voltage drops to about 11.8-11.9V. I was getting a reading of 14.2V on KOEO, KOER, idle, 1500 and 2500 RPM just after the install and a few days after. I have no clue why all of a sudden I am getting this reading off my multimeter.
I read up awhile ago on a bronco forum that some install might require a ground cable from the alternator to chassis. Is that what my problem is? Did I just fry my alternator, would a new regulator fix it if I indeed fry it?
Thanks in advance guys!
Pull the alternator and take it to the parts store where you bought it. They can bench test it to determine what is wrong.
