Have any of you installed your own mid pipe using ramps?
I did a dry run and it was not a comforting feeling being under that car much less with such little room. I think I need more reinforcements.
Should I get Jack stands for this mission? What other safety precautions do you take when lifting your car?
I''m thinking that I may need jack stand/floor jack. Any brand that you'd recommend? What's the minimum weight (1 1/2 ton, 2 ton, or 6000 pounds).
Have any of you rotated your own tires? Is this something that only involves swapping driver-front to passenger rear, etc.
