  • 2.3L (N/A & Turbo) Tech
SOMEBODY HELP PLEEZE!
  • Thread starter Thread starter ELGUAPO91LX
  • Start date Start date May 13, 2004
E
ELGUAPO91LX
47
SOLON,OHIO
May 13, 2004
  • May 13, 2004
I STILL CAN'T GET MY '91 2.3L-'87 2.3T SWAP TO RUN. WHEN I TURN THE KEY IT STARTS AND SOUNDS LIKE IT IS RUNNING BUT THA SECOND I RELEASE THE KEY TO THE RUN POSITION IT CUTS RIGHT OFF. MY FATHER AND I HAVE RESET THE TIMING SEVERAL TIMES, EVERYTHING IS LINED UP SO IT IS AT TDC. I WAS TOLD TO CHECK THE IGNITION SWITCH, THE OLD ONE SEEMED OK BUT I REPLACED IT ANYWAY ALONG WITH A NEW TUMBLER. THAT DIDNT MATTER STILL DOING THE SAME THING. ALL THE WIRING AT THE COMPUTER IS RIGHT I WENT OVER IT SEVERAL TIMES, ALTHOUGH THE ONE THING THAT BOTHERS ME IS THAT AT THE #37 PIN WHICH IS A 12V VPOWER HAS NO POWER AT IT WHEN I USED A CIRCUIT TESTER ON IT. ALSO, I TESTED THE 12V WIRE GOING INTO THE MODULE UNDER THE HOOD BUT IT DOESN'T HAVE POWER IN THE RUN POSITION BUT IT HAS POWER AT IT WHEN IT IS STARTING. CAN SOMEBODY SHED SOME LIGHT ON THIS IF YOU HAVE ANY CLUE WHAT MIGHT BE GOING ON HERE. SUMMER IS HERE AND WANNA ROLL!!
rgosulliv
430
Lawrenceville NJ
May 13, 2004
  • May 13, 2004
I had a similar problem with mine. mine ran in the crank position and cranked in the run position.
I pulled the TFI module harness off and tested the voltage at both postions crank and run and they were backwards as i expected but i couldnt figure out why. turned out that when i wired the tranny i reversed two wires which made one end up being a constant hot which messed with the ignition.
So i guess what I'm saying is pull the TFI module harness off and check to make sure your getting the right signals based on the key position and then go from there.
spunky4343
46
  • May 17, 2004
i had that problem once and i drove to the mechanic holding the key, turns out it was the key cylinder, changed it and never had a problem again
hope it helps
E
ELGUAPO91LX
47
SOLON,OHIO
May 18, 2004
  • May 18, 2004
thank you guys for your advice i will try taking off that tfi module and see wuts going on, and then i will go for there
E
ELGUAPO91LX
47
SOLON,OHIO
Jun 7, 2004
  • Jun 7, 2004
I checked out the TFI and everything seems to be in order there, however we have found that we dont have power at the injectors in the run position, does anybody know what the cause of this could be? any help would be appreciated
bhuff30
6,037
35
129
Olathe KS
Jun 7, 2004
  • Jun 7, 2004
The injectors are pulsed, so you need an oscilliscope to see what they are doing.
You only need a few things to start it...
1. Check for spark (pull a plug, leave the wire on, and ground the threads. you should see a strong spark when cranking. Just don't shock yourself!
2. Fuel. Check for fuel pressure. it sounds like the pump could be dead, or dying
3. Timing. Double check it again.
4. compression
Dr_EluSivE
2,155
Central Illinois
Jun 7, 2004
  • Jun 7, 2004
its a common problem usually caused by a bad Ign switch.
Dr.
Stinger
7,754
24
118
Basehor (Kansas City), KS
Jun 7, 2004
  • Jun 7, 2004
Did you remove the extra wires no longer needed in the ignition harness?
Mustang5L5
Mod Dude
Feb 18, 2001
43,264
17,952
224
Massachusetts
Jun 7, 2004
  • Jun 7, 2004
Stupid question, but did you hook up the wires on the starter solenoid right??
All the wires except the starter wire on one post, the starter wire on the other post.
I only ask because i've seen it happen
Bearded Forever
Type O Danzigative the Dark
4,927
Vinland
Jun 7, 2004
#10
  • Jun 7, 2004
  • #10
Did you try hitting the CAPS LOCK BUTTON OMFGWTFLMNOP!
E
ELGUAPO91LX
47
SOLON,OHIO
Jun 8, 2004
#11
  • Jun 8, 2004
  • #11
these are the things that i have done
1. checked spark(fine)
2. checked fuel its getting it
3. also its a new fuel pump(less than 6 months old)
4. change ignition switch and tumbler
5. checked timing about 50 times
6. changed timing belt
7. then see # 5.
but i will get an oscilliscope to see what the injectors are doing, my father says he has something to check the compression...I have not remove the extra wires from the ignition harness, i was told it would be better not to until everything was in running order, but that is another thing that i will look into. also, i am pretty sure that the wires on the starter solenoid are hooked up right but i will double check to make sure...thanks for u guys help, and i am open to any other suggestions
Stinger
7,754
24
118
Jun 9, 2004
#12
  • Jun 9, 2004
  • #12
I was asking about the ignition harness because I thought you may have removed a needed wire on accident...if you haven't removed them yet that's not the problem though.
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
Did I fry something messing with my ignition?
  • 85gtCOBRA
  • Oct 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 15, 2025
85gtCOBRA
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 4, 2026
manicmechanic007
