Somebody help!!!!!!!!!!!!!!
chevy_impala57
I got the car from a buddy Dont know if if was running bad before all i know was the plug plug in number 4 Kept coming out crushed
So i took a motor with 153 000 km on it and swap it in.
When i go to start it i have to hold my foot to the floor it pops and fires trys to start. Then when it dose finally catch on it stumbles and bearly wants to run(foot still to the floor) THen after 20 seconds or so Its Reves out to 5grand and clears its self up and runs. Runs good starts goods. Then let it sit for a couple of hours Dose the same thing
When you Frist go to start it, it sounds like a car the distrubuter at -5 degress. Then when it dose catch on it sounds like a flooded carburated car. Any ideas
As Well theres a plug I have no clue Where it gose its driving me nuts. I traced the wires to the ecm its pin 53 and pin 52 ,,, acording to my book But m book dosnt show 52!!! Will this effected how it Runs?
The Car is a 93 ford Mustang 2.3 dis
Any ideas To my porblems thanks
Michael Kaplan
if the #4 plug isnt firing your car isnt going to run very well. first thing I would do is pull the head and see why your plugs keep getting crushed. once that is resolved I would get the computer scanned to see what other issues it has. I wouldnt bother tracnig wires to the ecm. fix the problem with your #4 cylinder and scan the computer. with EFI you are pissing in the wind without a scanner. too many things have the same outcome.
You need to at least set the current engine up with safe base timing so that can start. Make sure the spout is then plugged back in.
Do the basic checks that the fuel pump primes and the rail has pressure when it tries to start. Make sure the plug wires are in the right order, and are not broken.
Also it sounds like you may have a vacuum leak somewhere.
As you have already gotten to the puter, make sure all of the grounds are good. Bat to body, bat to engine, bat to puter, etc.
And, yes, without a scanner, or at least going through the check engine light code reading effort, you are trying to push a logging chain uphill.
ahahahah I must not have made it clear. Thats why i swaped the engine. But i think have may have figgured it out. The donnor car was a 92 mines a 93 i put the 92 coils on. The firing order is diffrent, ill see after work if that fixes it.
