SOMEONE PLEASE HELP! I cant fill my gas tank up....!!!!
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
I went to try to fill up tonight and it was acting like the tank was full where the pump automatically shuts off. I know its empty because the guauge says so and i always reset my mileage and im at about 240miles. I tried 3 different pumps at 2 different stations and get the same result.
I put in a fuel pump about 2 weeks ago. I have filled up about 4 times since. I have no idea on what could cause this.
I got the gas can and filled it up and then filled the tank up to a quarter tank and i am guessing this worked because of the lower pressure but i still had to pour it verryyyyy slow. I know there is a flap that only works one way in the filler tube...is it a chance that is stuck?
ANYONE give me any insight before i take the filler tube down tomorrow morning. This is going to be a pain :bang:
HELP :(
yellow5.0cobra said:
Just ease the pump up and down till you find the "sweet" spot.
Ever notice how funny that looks?
:lol:
Used to happen to me but it just stopped. People always gave me weird looks while doing that, like I was molesting the car or something! :lol:
so its the sensor on the pumps? What do you think is causing the gas to go in slowly with the gas can then? I never filled it up with one before so it could be perfectly normal. It just seemed like i couldnlt just turn the can upside down cause it would go in too fast and start coming back out.
No need to tear down the filler tube assembly? :banana: Thanks guys...this is a relief
Your problem is your filler neck. I had the same problem. After speculating on the message boards for weeks I finally just dropped the tank and examined the neck only find that the filler neck's flap that's inside the tank was stuck shut. So, I just ripped it out with plyers. No big whoop. Pump still shuts off by itself which is what I was worried about. It seems as though that flap is only to prevent gas from spilling in the event of a roll-over.
So if you're planning on rolling over just replace the filler neck.
hmmm thats what i thought.....
HAHA no not plannin any roll overs any time soon. Thats where i thought the problem was because tonight i tried again to move the pump around in the filler tube to no success. It only goes in at a very slow rate so im thinkin its either completely stuck closed or partially closed. Im glad someone has been here and i know i wont be droppin the tank tomorrow for no reason.
:bang: Droppin the tank twice in one month :bang:
Wish me luck
Thanks for everyones advice!
