  • 1994 - 1995 Specific Tech
SOMEONE WITH STEREO KNOWLEDGE HELP ME PLEASE!
  • Thread starter Thread starter cb18201
  • Start date Start date Apr 13, 2004
First Prev 2 of 2
cb18201
1,140
CT
Apr 14, 2004
#21
  • Apr 14, 2004
  • #21
Ed Calvert said:
My experience with these things are that noise or static has a source. It could be ignition noise(spark plugs firing, alternator, etc.). You may have a situation of inadaquate grounding. Poorly grounded wires act like antennas that can pick up radiated noise. Check all grounds including the ground strap under your hood that goes to your hood liner(which is conductive on one side). This helps shield the antenna from ignition noise coming thru your fiberglass hood. Mostly for AM radio though. Try re-seating the connectors on the radio. Can you hear the static change pitch with change in RPM? Does it go away if the engine is off? Keep in mind that an amplifier is just that, an amplifier. If radiated noise gets into the amp. via poor grounding, unshielded wires, it'll kick it out to the speakers. One other possiblity...assuming that at one time everything was working at one time, the spark that you referred to when the hot wire touched ground may have taken out a suppression capacitor in the amp. Try placing a capacitor between the +12V wire and ground close to the radio and/or amp. and see what happens. Radio shack can hook you up....BUT... make sure you get the polarity correct or you risk blowing the capacitor up. One more option, call a Ford dealer and ask. It can't hurt. Try strapping the radio and / or amp. case to chassis, basically making your own ground. Multiple wires to gound make a lower impedance path. This might help. I'll check with some more people tomorrow and see if I can dig up anything else.
thanks man i appreciate it alot
haulbalz
448
#22
  • Apr 14, 2004
  • #22
check your ground
cb18201
1,140
CT
Apr 15, 2004
#23
  • Apr 15, 2004
  • #23
well what do you know, i got my new battery and my stereo is no longer acting up, it is perfectly fine now, it is amazing what having an almost dead battery can do. so if your speakers thump when you turn your lights on or any dash switch then you know your battery is almost dead. thanks for the help guys
First Prev 2 of 2
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
R
2004 mustang convertable need help please
  • realbkg
  • Mar 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 1, 2025
89ripper
A
need help and advise
  • amps1956
  • Oct 14, 2025
  • Other Auto Tech
Other Auto Tech Oct 21, 2025
Mcmahst
