Something is seriously wrong.....but I don't know what
Ok, it's been an ongoing quest to get my car to run even "normal" times. I put the stock meter back in due to the fack that the car was detonating at high RPM, namely at the top end of the track and I've replaced the fuel filter(normal service). I went back to the track, same weather(hot and humid) and it wouldn't run any better, the MPH is low(89-90) and the timeslips are in the low 15's. I, as well as the other guys I've talked to think the car is hurting big time on the top end. I can't seem to figure out what could be causing the car to be running so flat? It drives fine and seems to pull around town just fine. Does anyone have any ideas to what I can look into to help solve this problem? I know it's kinda vague but there isn't any real symptoms other than it's slow. I would like to have this straightened out before I do my headswap. . .Lemme know what I should check (it's probably something simple and stupid).
