something wrong with my car
OonDeanisS
902
Danbury, CT
i have no idea whats wrong with my car... it runs fine one minute, and the next it stalls(while driving and idling) randomly and wont start. It makes all the noises it should except it doesnt ignite. I always get out and check the coil wire and spark plug wires, starter solenoid, spark plugs, coil bracket, and a couple other ground wires in the engine bay (one going between the solenoid and engine bay, and one that goes between the engine bay and coil bracket) i also check the wires on the back of the alternator. Then it might start and might not. if it doesnt, i do it all again until it starts cuz eventually it does. wtf? anyone have this problem? :shrug: :bang:
things you need to check. when it does this, try to ground a plug or have a fuel pressure gauge hooked up, so you can isolate if it is fuel (likely pump) or ignition (likely TFI) related. could be a bad ignition switch too, but that should show up while testing ignition and fuel. but i would check the former two, as i think they are more likely (both are heat sensitive when failing - get hot and fail, cool off and may come back to life).
i dont suppose you are spittin any codes?
just my two cents from 2 seconds worth of thoughts.
good luck.
Carb'd cars require an old time approach to troubleshooting.
1,) Pull the air cleaner and sniff for fuel vapor - look for signs of flooding. Don't see any evidence of flooding? Then pump the throttle - does the accelerator pump squirt fuel? If so then you have enough fuel to start the engine. If not look for fuel delivery problems. Check the fuel pump, and fuel filter.
Now that you know that you have fuel, check the ignition.
2.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) Coil
B.) Distributor PIP sensor
C.) No power to ignition system wiring or ignition box (if used)
3.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
4.) Spark at spark plug, but no start.
Next, get a can of starting fluid (ether) from your local auto parts store: costs a $1.30 or so. Then pull the air duct off at the throttle body elbow, open the throttle, and spray the ether in it. Reconnect the air duct and try to start the car. Do not try to start the car without reconnecting the air duct. If it backfires, the chance for a serious fire is increased.
