Well I bought my 94 5.0 with about 126k on the odometer, a couple weeks back I decided it would probably be wise to go through and change out all the fluids. I flushed the radiator coolant, changed out the gear oil in the diff, changed out the oil (of course while it's in the air) and also changed out the manual trans fluid.
Here's the problem. Ford calls for Mercon automatic trans fluid, so I drained all of the old out, reinserted the lower drain plug to torque spec, and pumped in the new fresh fluid to spec. I reinstalled the upper fill plug to torque spec. I've driven the car say 100 miles or so since, and noticed the trans fluid has been leaking a bit. About a silver dollar sized puddle on the floor of the garage. So tonight I put her up in the air, and noticed a bunch of grime mixed with trans fluid coming from the area of the upper fill plug. I grabbed to carb spray, cleaned the area up and about died when I saw where the upper fill plug is on the trans housing is about a 3/4 inch crack! Definately the source of the leak. Dammit!
So... in lieu of changing out the trans what can I do? Mainly this crack is limited to the area just on the side of the fill plug facing the back section of the car. I imagine some may have had this happen before. Any info/ideas on a fix would be great.
