  • SN95 4.6L Mustang Tech
sorry guys stupid question about eibachs
  • Thread starter Thread starter Modular2v
  • Start date Start date Jan 26, 2004
Modular2v
3,222
23
99
oklahoma
Jan 26, 2004
  • Jan 26, 2004
hey guys i just got my eibachs today and im just now attempting to install them so expect me to be asking alot of questions over the next couple of days just incase i screw up.
question#1 LOL which springs go where? do the shorter ones go in the back and the taller in the front?
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Jan 26, 2004
  • Jan 26, 2004
they shouldnt fit but one way man , right and left dont matter LOL
speed545
458
Montreal, canada
Jan 26, 2004
  • Jan 26, 2004
Heaviest goes front
Attempting is not an option, cause when your stock ones are off and you could nt install eibachs..............you re screw.
Back is real easy. can do it alone in 45 minutes. Front, is a bit tricky but i did mine with help of my brother in 2 hours.
Good luck
Modular2v
3,222
23
99
oklahoma
Jan 26, 2004
  • Jan 26, 2004
no i know left and right down matter but front and back do!!! do the short ones go on the back?
GTblack_00
494
Tampa Bay Area, FL
Jan 26, 2004
  • Jan 26, 2004
the spring with the thicker coil goes in the front, smaller coil wire spring in the back.
mpcv2000
2,371
Montreal , Quebec !
Jan 26, 2004
  • Jan 26, 2004
Impossible to mix them up.... Biggest coil are made for heavier weight so they will go up front... If you remove one you'll see...You're sure you want to do it yourself..
Modular2v
3,222
23
99
oklahoma
Jan 26, 2004
  • Jan 26, 2004
oh guys you know what..i just realized that i was a complete idiot for asking this question and it was all figured out with common sense. Well im happy to report that iam done with the rears and will tackle the task of the fronts tomorrow with the help of a friend. thanks for all your help guys your the best
mpcv2000
2,371
Montreal , Quebec !
Jan 26, 2004
  • Jan 26, 2004
Cool ! You got the back in..
If you want you can read this ! Springs installation instruction
Link if from a moderator's web site !
C
claytucc3
825
Santa Clarita, Ca
Jan 26, 2004
  • Jan 26, 2004
Cool, the rears are a lot easier than the front, but it is still easy. Are you using the pro kit or sportline? Since you are going to need to get it all aligned I would suggest installing a set of offset steering rack bushings to help with your bumpsteer they are only like 15 bucks. Just my .02
clay
Modular2v
3,222
23
99
oklahoma
Jan 26, 2004
#10
  • Jan 26, 2004
  • #10
one question guys...the backs are in! but i set the bottom pigtails of the new springs the exact same way the old ones were facing. Is that the right way to do it because the directions that came with the spring tells me to set them a different way which one should i do? I have always been told that u make sure the bottom pigtails are facing the same exact way as they were before
Modular2v
3,222
23
99
oklahoma
Jan 26, 2004
#11
  • Jan 26, 2004
  • #11
im using the pro kit by the way! i forget what is different about the sportlines?
S.D.-Stangman
580
San Diego, Ca
Jan 27, 2004
#12
  • Jan 27, 2004
  • #12
The pigtails should both be pointing directly toward the drivers side of the car if I remember correctly. Some correct me if i am wrong?
C
claytucc3
825
Santa Clarita, Ca
Jan 27, 2004
#13
  • Jan 27, 2004
  • #13
LOL....I understang that you want to make sure everything is OK. Jus tfollow that paper that came with the springs.
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
P
Air Fuel ratio bung location.
  • Praetorious
  • Feb 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2026
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
T
What's it Worth? 2002 GT conv/auto
  • tonydetesta
  • Jan 7, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jan 21, 2026
Mustang5L5
