Sos Foxbody Lovers.
JRs90GT
I am new to this forum, and love all the information here. I have a 1990 GT and its basically stock. I have an issue with my stang running rich. Recently replaced all 3 capacitors on my A9L computer, replaced maf, bap, tps @98volts, coolant temp and both 02 sensors and installed a cold air intake system and removed the factory cats but left the air tube intact on it. Also am running accell ignition coil and a spark plug gap of .060. There are no codes currently stored in computer. I have not yet replaced the manifold air temp sensor. Am at a loss and can't understand why she's running rich any help would be appreciated greatly. Thanks Stang lovers.
Did you have this problem before you removed the cats? The sample tube that connects to the cats takes readings of I think the gas left in the exhaust?(something with smog crap) That along with you o2 sensors can change your fuel mixture in the computer.
I too would like to know what makes you think it's running rich? What's going on? How is the car running otherwise? Does it idle and drive fine? Removing the Cats won't throw off your computer and make it dump fuel however it can leave you smelling a little more like gas but doesn't mean you're running rich in the engine.
I"ve ran an h-pipe without cats off an on for the past 10+ years(finally got high flow cats last year, state inspections suck). I was even doing it when I had factory speed density setup. Mine smelled rich at the exhaust but ran fine. Without a wideband sensor we are just quessin what the fuel ratio is. Your computer makes these adjustments.
Is there something else going on here? I see your gap is at 0.06(I think stock is 0.04?). is that what the ing. said to put it at? you might want to adjust that. What is your timming set at? If your running that much of a gap and your timming is still set to stock spec. your not going to have full combustion.
Reactions: stangboy
No code 11 (two flashes when the computer dumps the codes)? A perfectly functioning system will always get a code 11, it is the everything is OK code. The 11 code is computer passed its internal self test.
If you don't get an 11, you have computer or wiring problems.
Please check and repost.
Hi Guys & Gals, Yes I have removed the cats. I do get a code 11, but will recheck the ecm again. The reason why I am asking is because prior to replacing the cats the exhaust smelled the same(as if all the fuel isn't being burned completely. I truly think it maybe a tps issue. The plugs are gaped at .060 . Two things I noticed the other day is that with the A/C on the temp is a little high, not overheating. Also when I turned the headlights the temp gauge drops a bit, strange... I love my stang I just want it running rite. My gas mileage to a full tank is about 170 to 190 mpg. My timing is set to 12 btdc, I did hear some pinging the other day when the a/c was on, but the temp was in the normal range according to the gauge. I have also replaced the distributor with a brand new one. Do u guys think it might be my temp sensor or a fuel injector issue. Thank you all for your feedback.
