Spark help
  • Thread starter Thread starter J90GT
  • Start date Start date Sep 15, 2005
J
J90GT
73
  • Sep 15, 2005
hello, i picked up a half built 90 GT Mods are as follows
Ported stock heads
1.6 cranes
B-cam
Typhoon intake
CAI with 73mm MAF #30 with 30lbs injectors
Diablo chip
SHorty headers to straight pipes with flowmaster dumps
bbk 70mm TB
It was just dynoed a few weeks ago made 262HP/283TQ, seems OK
So i purchase the car few days ago, it pops and gurggles when i left off the gas. So i assume the spark is jacked up. Should i run a colder plug with this set up even though its pretty mild or just gets replacements? and what GAP. Should be used? Thank you
J
J90GT
73
  • Sep 15, 2005
Help?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 15, 2005
  • Sep 15, 2005
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
J
J90GT
73
  • Sep 16, 2005
Thats the problem the CEL isn't on. I put a new distributer,wires,02's it has a new TB so the TPS is new it was just dynoed/chipped 2 weeks pryor to me buying it with a dead even 13.5 A/F.
Now its running pig rich, If i turn on the a/c i can get high off the gas fumes coming thru the vents. Im at a loss here, only thing i havent replaced would be plugs which were black but i doubt that is the sole problem.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 16, 2005
  • Sep 16, 2005
The CEL light does not have to be on for there to be codes stored in the computer.
The 30 lb injectors are way too big for a 302 with no power adders. The computer would have trouble trimming the injector pulse width to give a suitably lean mixture for street use.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Sep 16, 2005
  • Sep 16, 2005
The popping / backfiring is from unburnt gas igniting in your exhaust (FWIW)
Get some smaller injectors, check your timing
J
J90GT
73
  • Sep 16, 2005
timing was set at 36 degrees advanced seems kinda way out ???
I think i'll just swap out the maf and injectors for some 24#'s and start from scratch
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Sep 16, 2005
  • Sep 16, 2005
Did you check your timing with the PIP sensor unplugged? It should be around 10 Degrees (stock ) and usually up to 14 Degrees (tuned)
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Engine Popping noise in the intake. Frustrated still.
  • esteban31065
  • Apr 6, 2025
Fox 5.0 Mustang Tech May 23, 2025
gkomo
L
Engine Need help diagnosing 2 dead cylinders
  • lvgnmz
  • Feb 13, 2025
Fox 5.0 Mustang Tech Feb 13, 2025
Mustang5L5
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
keel
