  • 1994 - 1995 Specific Tech
spark knock??? pinging?
  • Thread starter Thread starter 1995greenstang
  • Start date Start date Jul 11, 2008
1995greenstang
89
  • Jul 11, 2008
engine pings under load just had custom chip burned for 87or 93 octane and egr/smog delete thinking this would solve the pinging problem but it didnt car was hesitating at high rpms, like it was running out of gas so i took a look at the maf and low and behold it was completely flithy so cleaned it and now it s a totally different car tons of torque but its still pinging under load anyone have any ideas? i have checked vaccums no vaccum leaks brand new plugs gapped to manufacturers specifications i think 54, brand new distributor, msd rotor and cap any help is greatly appreciated or what i could look at to see if its casuing the problem thanks
desertcox05
379
south atlanta
Jul 11, 2008
  • Jul 11, 2008
what is you timing set at? go to far and it will ping under load. stock time is 10 btdc. most peps will take the timing till it starts to ping then back it off a hair. i think mine is at 12 so i can still run 87 octane
1995greenstang
89
  • Jul 12, 2008
ive set it at all degree,s with no change still pings .
Stanger007
2,015
Baton Rouge, LA
Jul 12, 2008
  • Jul 12, 2008
Make sure the balancer is in good shape! I've seen them spun so that they are not reading correctly when the timing is set.
Also make sure something isn't rattling around under acceleration and sounding like ping.
I'd go down in two degree increments on the timing until the pinging stops.
Wes
Stevenlgts
24
Atlanta area
Jul 12, 2008
  • Jul 12, 2008
Check your coil. I had a pinging problem and damn near replaced ever possible engine part that could be a possible culprit including the timing chain, distributor, fuel pump...and many other parts...turned out to be my coil!
1995greenstang
89
  • Jul 13, 2008
hey thanks for the input guys the dam damper is bad the outter weigth spun so timing was wacky but got it good now tHANKS.
Stanger007
2,015
Baton Rouge, LA
Jul 13, 2008
  • Jul 13, 2008
Good catch. I bet your car will run smoother with a new one as well if it has spun.
I've had good luck on my personal car and many others that are beaten regularly with the Professional Products SFI balancers. Have also put on the non-SFI units and they have held up great.
If you go this route be sure to get the proper spacer as well.
I would not go back with a replacement style balancer, they all seem to have the same issues over time.
Wes
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
Fuel Spits sputter pops and bangs under load. Help wanted
  • sickntired
  • Mar 23, 2024
4K
Fox 5.0 Mustang Tech Apr 1, 2024
sickntired
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
