Spark Plug advice for AFR 185's
jcode68
892
Massachussetts
I did a quick search, but couldn't find a quick answer. What spark plug/heat range are you guys using for AFR 185's? Their website spec says "spark plug starting range Autolite 3924". Is this an ideal heat range or what is the best way to determine what is right? I am on the East Coast in MA and do not drive the car in cold weather. Thanks in advance for any education.
Thanks for the link. I haven't fired the engine yet, and am looking for a good starting point. Engine is 347 stroker with 9.5:1 compression, using the Crane Hi6S ingition with PS91 coil. I notice you live in AZ, which is really different climate than me. I will probably try the 3924 unless someone gives me information otherwise. Thanks to the link you sent, I will be able to read the strap and change accordingly.
Thanks for another good link. I think I have a starting point and will read the plugs after a few miles to see if I need to adjust. I'm not running high compression or using nitrous, so I suspect I will be ok.
