  • SN95 4.6L Mustang Tech
Spark plug blowout?
  • Thread starter Thread starter imblown-ru
  • Start date Start date Mar 6, 2006
imblown-ru
247
Roanoke VA
Mar 6, 2006
  • Mar 6, 2006
What does the loose spark plug in the head sound like? Is it a constant ticking, or only at certain speeds? is it fast? I have a noise that sounds like a rattle in the dashboard up by the firewall, and i cant figure out what it is, just wanted to make sure it wasnt a plug...
mrvax
Stay thirsty my friends
SN Moderator: Orlando, Fl.
Mar 6, 2006
  • Mar 6, 2006
If a spark plug blows out...you'll know it. It will sound very loud like a motorcycle under the hood.
imblown-ru
247
Roanoke VA
Mar 6, 2006
  • Mar 6, 2006
i know i will be able to tell it if it happens, but the noises leading up to that.
stangGT97
1,299
Boston area, MA
Mar 6, 2006
  • Mar 6, 2006
well, when i installed my plugs, i didnt torque cylinder 5 enough, and it was a constant tick that went with RPMs... there was also a noticeable misfire. The best way to be sure is to take 20 minutes of your time, and retorque the plugs with a torque wrench. It sure would be a shame to have to buy new heads when the whole problem could be avoided with some simple checks. good luck
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Mar 6, 2006
  • Mar 6, 2006
there are ticking noises BEFORE the plug blows out. it sounds like a tapping and canbe heard outside of the car louder than it can be inside. it's louder as you get into the gas.
if you catch it at this point you can retighten the plug down.
01Steeda
732
Baton Rouge, LA
Mar 6, 2006
  • Mar 6, 2006
COULD IT BE COMPARABLE TO THE SOUND OF A HEADER LEAK? i HAVE A TICKING THAT SOUNDS LIKE THE HEADERS.. I BETTER DBL CHECK THEM PLUGS LOL. SRY CAPS.. I AM AT WORK AND IT IS ALWAYS CAPS.
imblown-ru
247
Roanoke VA
Mar 6, 2006
  • Mar 6, 2006
i would go check my plugs, but it seems like such a damn hassle. Is it a pain in the ass to get to them? It sounds like a rattle in the dash, but who knowwsss...its driving me nutzzzz
Mike97gt
it doe snot
10,633
Mar 6, 2006
  • Mar 6, 2006
it's better to be safe than sorry. the plug are easy to get to. one 7mm holds in each coil. remove the 7mm and the coil pulls right out. you don't have to take the fuel rails out.. the coil is flexible
imblown-ru
247
Roanoke VA
Mar 6, 2006
  • Mar 6, 2006
you can do it around the fuel rail? ok i will see what i can do tom. Are there any common cases of rattling in the dash board?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Mar 6, 2006
#10
  • Mar 6, 2006
  • #10
My Mustang has more squeaks and rattles than any car I have ever owned...
Mike97gt
it doe snot
10,633
Mar 6, 2006
#11
  • Mar 6, 2006
  • #11
kilgore you have a vert. those have even more squeeks and rattles than a regular mustang
jasonh_86
I
May 20, 2005
1,156
Arkansas
Mar 6, 2006
#12
  • Mar 6, 2006
  • #12
my car has a few rattles but there's 1 main rattle.. it's in the dash somewhere between the glove box and the center part of the console.. deep down in there somewhere.. sooooo aggrivating on long trips
The other's are in various places and rarely rattle, none are ever really constant
imblown-ru
247
Roanoke VA
Mar 6, 2006
#13
  • Mar 6, 2006
  • #13
i think thats where mine is
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Mar 7, 2006
#14
  • Mar 7, 2006
  • #14
Yeah, I know...
It is worth it though
H
HercFE
55
Sacramento
Mar 7, 2006
#15
  • Mar 7, 2006
  • #15
I just tossed a plug in my car, I thought I had a small exhaust leak from the right side of the motor, then it blew, you will know when it happens. Smelled fuel and had no power at all, had to keep my foot on the gas to keep it running. The tech at Ford tried to blame my aftermarket plugs, said one was loose, which is , I put them in and know they were tight. I would check your plugs to be safe though!!
Mike97gt
it doe snot
10,633
Mar 7, 2006
#16
  • Mar 7, 2006
  • #16
they loosen up first then blow out. that "exhaust" leak was the plug ticking away. thats the noise i have been talking about on here for atleast a year.
don't feel bad they loosen up even when toruqed down to factory spec.
a lot of people put antiseize on the plugs ( i do to now) but that does nothing to help to prevent blowouts. the problem is not the plug seizing. it's the oposite the plugs loosen on there own. the antiseize will help to keep the threads from getting screwed up when removing the plugs later. and mangled threads will only make it easier for the plugs to come out.
to this date there is nothing that can be done to prevent them from loosening, ford did have us locktite some lightings in the 2003 model year and the plugs stay tight that way. BUT the threads become damaged when you remove the plugs. I tested this on a set of heads and the threads on the head were damaged after cracking the plugs free. so close but no cigar on that one.
the only thing that does work. is install the plug with antiseize at the top end of the tourqe spec and recheck them every other oil change.
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
393W Stroker with Boost - Need Spark Plug Recommendations
  • 387lx
  • Apr 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 30, 2026
HotFox
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
