Spark plug blowout?
imblown-ru
247
Roanoke VA
What does the loose spark plug in the head sound like? Is it a constant ticking, or only at certain speeds? is it fast? I have a noise that sounds like a rattle in the dashboard up by the firewall, and i cant figure out what it is, just wanted to make sure it wasnt a plug...
well, when i installed my plugs, i didnt torque cylinder 5 enough, and it was a constant tick that went with RPMs... there was also a noticeable misfire. The best way to be sure is to take 20 minutes of your time, and retorque the plugs with a torque wrench. It sure would be a shame to have to buy new heads when the whole problem could be avoided with some simple checks. good luck
my car has a few rattles but there's 1 main rattle.. it's in the dash somewhere between the glove box and the center part of the console.. deep down in there somewhere.. sooooo aggrivating on long trips :mad:
The other's are in various places and rarely rattle, none are ever really constant
I just tossed a plug in my car, I thought I had a small exhaust leak from the right side of the motor, then it blew, you will know when it happens. Smelled fuel and had no power at all, had to keep my foot on the gas to keep it running. The tech at Ford tried to blame my aftermarket plugs, said one was loose, which is :bs: , I put them in and know they were tight. I would check your plugs to be safe though!!
they loosen up first then blow out. that "exhaust" leak was the plug ticking away. thats the noise i have been talking about on here for atleast a year.
don't feel bad they loosen up even when toruqed down to factory spec.
a lot of people put antiseize on the plugs ( i do to now) but that does nothing to help to prevent blowouts. the problem is not the plug seizing. it's the oposite the plugs loosen on there own. the antiseize will help to keep the threads from getting screwed up when removing the plugs later. and mangled threads will only make it easier for the plugs to come out.
to this date there is nothing that can be done to prevent them from loosening, ford did have us locktite some lightings in the 2003 model year and the plugs stay tight that way. BUT the threads become damaged when you remove the plugs. I tested this on a set of heads and the threads on the head were damaged after cracking the plugs free. so close but no cigar on that one.
the only thing that does work. is install the plug with antiseize at the top end of the tourqe spec and recheck them every other oil change.
