  • 1994 - 1995 Specific Tech
Spark Plug change Question
  • Thread starter Thread starter RedStallion43
  • Start date Start date May 20, 2005
RedStallion43
61
Chi-Town
May 20, 2005
  • May 20, 2005
Changing Spark Plugs
Ok, I figure its time for a tune-up. I was planning on changing my spark plugs but I can't seem to figure out how to change 4 of them. I can see the ones on the one side but not the other. Does anyone have a write up on how to change them? Also, what kinda plugs do you guys reccomend? My car is stock besides an air filter and hopefully soon, exhaust.
GRGT1994
1,034
  • May 20, 2005
I changed my plugs without doing anything special. I did pull the air box, and I used a couple of extensions and a universal joint. It took some persuasion to get at a couple of them. But most came out without too much of a fight.
Use some dilectric grease on the boots before you put em back on the new plugs. And you might want to hit the threads with a bit of antiseize.
I think most people prefer good ol' Autolite copper plugs (25 or 24, I can't remember. But the parts shop can tell you).
If you run a search, I am sure you can find tons on spark plugs.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
May 20, 2005
  • May 20, 2005
if you pull the ducting for the intake it makes the plugs on the passenger side easier to get to
HISSIN50
34
129
May 21, 2005
  • May 21, 2005
well said. 25's are stock. 24's are one heat range colder than stock. if one has non-stock heads, they take different plugs.
a short and long wobble extension and a quality universal swivel are must haves. i use an air u-joint swivel since it is a ball-in-socket design rather than an articulated joint that binds. a wrench that does not require many degrees to latch is nice (some of mine are real sloppy, but i have one good one which does not get used except for tight clearances).
neverseize and dielectrical grease are great ideas.
good luck.
BDAWK2002
139
Old Bridge N.J.
May 21, 2005
  • May 21, 2005
I'm about to change mine too.Anyone got suggestions on gap for a stock motor?
Mustangless
903
home
May 21, 2005
  • May 21, 2005
.054?
96 GT 4.6 w/ dirty spark plug well
  • Mustang Momma
  • Apr 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2026
LILCBRA
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
F
Spark Plugs Caused Rough Idle & Driving
  • firevert
  • Sep 1, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 3, 2025
