Spark Plug Gap Question
  • Thread starter Thread starter 1BAD89GT
  • Start date Start date Jan 8, 2004
1BAD89GT
87
Oklahoma
Jan 8, 2004
  • Jan 8, 2004
Iam wondering if with this engine thats in my sig ,should i change my plug gap...i know stock is .054 but with this motor making 329hp@motor and having 10.7:1 compression,the plugs stay bright white.Im running a 155lph fuel pump and 40psi fuel pressure at idle on 93 octane.
edit:forgot one little detail timing is at 14 degrees
1BAD89GT
87
Oklahoma
Jan 8, 2004
  • Jan 8, 2004
*Bump* I figured this would be a stumper
thegabrielles
516
Atlanta Georgia
Jan 9, 2004
  • Jan 9, 2004
INTERESTING COMBINATION WITH THE B303, should run great, I am runnning .054 in mine as well, but I have considerably less compression than you do. Seems to me, your gap is not going to take care of a lean motor. I am running 45psi on my fuel with 24# injesctors and although I made more power with it leaner 2HP, the Air/Fuel was dropping off to far. With that compression you might want to bump up the pressure a bit. I take it you dynoed thee motor to get 329FWHP, did you run a dyno tune or just a couple of pulls to see what you got? Did they run the A/F on the pulls? I was told by FMS that .054 is wgere I shgould set the gap, hopefully thaey know their own motor.
sleeper89
388
Toronto, Ontario
Jan 9, 2004
  • Jan 9, 2004
as long as the plugs look good, she idles smooth, and the a/f ratios are good i would leave the gap as is. it probably wouldn't hurt any to close it up a bit with that much compression though. either way i would say you aren't going to see a big difference.
-steve
1BAD89GT
87
Oklahoma
Jan 9, 2004
  • Jan 9, 2004
Yeah when it was dyno'd it showed Air/fuel mix quality very poor all the way up to 2500rpms which im sure is from the aggressive lopey idle of the b-cam@226, and then the a/f jumps up to 91.4%@3000 and when stomping on it thats when it really seems to come alive you can feel an instant diff when it hits 3grand and above.the A/f Mixture shows to be 100% from 4500to6000
but whats weird is it showed a slight spark knock from 2500to4000 and computer retarded timing down to 26@2500, 21@3000 and 3500,and 27@4000.Yeah the b-came is pretty wicked with this setup,the machine shop who did all my machine work picked out a custom lunati for my motor and it was nearly identical to the B so i just opted to save a 120$ and go with the B.And man does this baby lope Hard!
LXMiker
159
Good ol' Wisconsin
Jan 9, 2004
  • Jan 9, 2004
1bad89gt
i am curious what you run in the quarter mile.............
please tell me if you know..........
1BAD89GT
87
Oklahoma
Jan 10, 2004
  • Jan 10, 2004
LXMiker said:
1bad89gt
I only go to run this motor once before the season end...Ran a 13.07@106mph
1BAD89GT
87
Oklahoma
Jan 12, 2004
  • Jan 12, 2004
Think i may have figured out some of my fuel problems took it back to my machinist shop today and we ran a few pulls with diffrent fuels and once i got up to 101 octane in the car the spark knock disappeared through the mid rpm range and produced a tad bit more HP....So basically i can run 93 during the week back and forth to work but on play days i need to break out the 101 octane
  • dan50
  • Jul 18, 2026
dan50
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
Fox Spark plugs
  • Mattjhop23
  • Jul 6, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 14, 2025
Reddevil91
F
Resolved Stumble issue upon acceleration (1987 GT)
  • FoxDude87
  • Sep 16, 2024
  • 2 3
4K
Fox 5.0 Mustang Tech Dec 3, 2024
FastDriver
