spark plug is white?
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Ok my 88Gt is stock block with eldlebrock uper and lower, 70mm TB, K&N, um...hollowed out smog pump and MAC LT's and O/R H with 2chamber flows out back. My fuel pressure gauge shows 38-40 psi under throttle and with new O2 sensors and car runs like a champ. Recently put Champion plugs in the car and have no complaints, stock timing , no detonation and motor pulls really hard to about 5600-5700. When I removed my plugs after about 175 miles to take a look at them the electrodes were covered with white/yellow deposit except where the spark transfers (what I call where the spark travels from the arch to the center portion) which is clean and the porcelen (spelling?) is white as if just out of the package..should I be concearned about the look of the plugs ..engine running lean?? and should I be worried about bumping the timing up to 14* from stock. Hey and while your at it give me a Quarter mile guess with 273 gear I'm thinking mid to high 13's if I get lucky with traction.
You nailed it with this - runs like a champ, pulls hard, no detonation. Your car/plug is just fine. Play with the timing if you like - if you advance it far enough to hear pinging, back it off a bit. And remember, the temps are a bit cooler this time of year. If you set the timing right on the edge of detonation now, you may have to back it off a bit when it warms up this summer.
Kind of how I was feeling. With the timing advanced is will I feel any difference in day to day driving, if no real diference I can't see the advantage to running with bumped timing
Yeah low 14's maybe without a gear change, but with the new LT's and H the car feels a hell of a lot stronger through the entire RPM range, I really feel like this set up will put a few high 13's on the board. 91notch lookin at your 60' time your probably lookin at a 1/2 second there yourself.
Anything is possible. My old combo in my 85 ran 13.8. With a stock suspension, drag radials, 3.55's, stock 86 302 and heads(crap), Ecam, RPM intake, demon 625 carb, mac shorties, and custom exhaust with dumps. I think my 60's were in the 1.6-1.8 range though.
