Spark plug question
  • Thread starter Thread starter 02GTRX
  • Start date Start date Oct 1, 2008
02GTRX
I told an admin to shut up...now I live with the S
20+ Year Stangneter
Sep 27, 2004
213
  • Oct 1, 2008
Whats the deal with the spark plugs on these S197's? I read something about a two piece plug... are they a pain in the arse to change? I have an 08 cs with nearing 20k and want to change them. Anything I need to know before I jump into it?
Sajeffc
27
Texas
Oct 1, 2008
  • Oct 1, 2008
I too have an 08. Look on the engine tag on the drivers side valve cover and see if it has "AB" in the middle of the numbers. If it does you're in luck! They changed the heads and plugs on the 08's built after 11/30/07 and went back to a conventional plug. You should have NO problems at all removing them. Let us know....
cave diver
81
Lake County, Florida
Oct 1, 2008
  • Oct 1, 2008
Next to "what oil should I use" the spark plug issue is one of the most common threads on all of the Mustang forums. Just do a little 'searching' and you'll get more than enough information.
Five Oh Brian
552
Pacific Northwest
Oct 1, 2008
  • Oct 1, 2008
Replaced my plugs at 15K miles with none of them breaking off. I followed the Ford TSB on the subject. You shouldn't "need" new plugs for 100K miles (the one good thing about the factory platinum plugs), but if you anticipate needing to change them (i.e. blowers, turbos, nitrous, etc.) then do it sooner than later and go with a good copper plug which has better thermal conductive properties than platinum. Colder heat range would be great for power adders, also. I used FRPP 3V0 copper plugs that are one heat range colder than stock and they made a world of difference in how my supercharged '07 GT runs!
NotQuik
5,158
29
88
Central Florida
Oct 1, 2008
  • Oct 1, 2008
I have alot 37k on mine, i've came to the conclusion that i'll just wait until 100k miles and hopefully at that same time it'll give me a reason to pull the heads and put ported ones on
02GTRX
20+ Year Stangneter
Sep 27, 2004
213
  • Oct 1, 2008
I checked and found the letters "AA" am I SOL?? are they really that hard to take off??
GTCS07
Rhode Island
Oct 1, 2008
  • Oct 1, 2008
Just pull them and coat the smooth part with anti-seize and reinstall.
Sajeffc
27
Texas
Oct 1, 2008
  • Oct 1, 2008
Well if you have AA on the sticker than yes, you have the old style plug. Yours must be an early 08 model. I don't think you're screwed you just have to follow the TSB to remove them hopefully without breakage!
96 GT 4.6 w/ dirty spark plug well
  • Mustang Momma
  • Apr 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2026
LILCBRA
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
F
Spark Plugs Caused Rough Idle & Driving
  • firevert
  • Sep 1, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 3, 2025
F
1986 mustang no start
  • foxyjamss221
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2025
foxyjamss221
F
