Spark Plug recommendations
Does anyone have recommendations for 5.0 n/a with AFR 165 heads and cobra intake and stock injectors? Also; 90mm mass air if that matters and also shorty unequal headers. No aftermarket ignition box, but I do have a fireball coil and summit billet distributor.
This is for my engine I just rebuilt in my 93.
looking for what the gap should be and if anyone has a recommended brand/part #.
TFS, Edelbrock, and AFR Heads:
[14mm, 3/4" Reach, 5/8" Hex, gasket seat]
AUTOLITE
1 step colder--3924 (4) [*recommended starting point]
2 step colder--3923 (3)
-----AR3933 (3) [*recessed tip, racing plug]
-----AR3932 (2) [*recessed tip, racing plug]
-----AR3931 (1) [*recessed tip, racing plug]
NGK
1 step colder--(FR5) 3686 (5) [*recommended starting point]
2 step colder--(BKR6EY) 3696 (6)
-----(R5671A-8) 4554 (8) [*recessed tip, racing plug]
-----(R5671A-9) 5238 (9) [*recessed tip, racing plug]
-----(R5671A-10) 5820 (10) [*recessed tip, racing plug]
MOTORCRAFT
1 step colder--AWSF22C
2 step colder--AWSF32C
AUTOLITE
MOTORCRAFT
This info is incorrect.
The Autolite plug heat ranges are as follows
3924 stock heat range
3923 is 1 heat range colder
3922 is 2 heat ranges colder
The Motorcraft plug heat rangers are as follows
AWSF-32C is the stock heat range in a copper plug
AWSF-22C is one heat range colder and
AWSF-12C is two heat ranges colder
