Spark plug wires, what is the difference.
glowstang93
Feb 9, 2003
853
Illinois
Is there any benefit from buying the regular spark plug wires for $21.99 versus the Borg Warner Tailor magnetic core wires for $43.99. I have the cheap ones on now, but am getting ready for changing the wires and plugs and was just wanting to know what the differences really are between the two.
P.s., this is a 2.3 dual plug.
Yea, I will probably buy the better ones, but was just curious on peoples opinions on how much better.
I have been told that the best plug for the 2.3 na is just the regular Autolite reg plugs $1.49 apiece.
Well, there's definitely a line where you're wasting your money. If your car is bone stock, you're probably wasting your money on $100 MSD plug wires. If you don't have the high power ignition to go along with it, and the dyno tune to go along with it...then it's pretty much a waste.
FWIW, i use a $50-60 Taylor 8mm set and i don't think i could improve on it, and i'm even running a Mallory ignition. Unless you're running high octane and high compression then you don't need race wires. I would steer clear of the parts store specials though...
You should be quite fine with some cheaper wires (i.e. Autolite) if you don't need bling Anthony. I've used the parts store stuff even on DIS vehicles and they do fine. And it's nice to have a LLT if needed.
That said, I run better stuff on the stangs, but it's for aesthetics and machismo.
Good luck.
I hear ya. The 21.99 ones have done fine as far as I can tell since 2004. I will probably go for the next level up, the magnetic core 43.99. I like to go a little above the base stuff. I feel a little better and think I'm taking care of her a little bit better. The guy at O'Reilly Auto Parts did tell me they have a little better boots and connectors (He wouldn't have told me that if it wasn't his real opinion, know him for about 5 years).
Thanks everyone.
Well got the plugs and wires done today. I used Autolite copper 764's and I went with the Bosch Wireset from Autozone. I was able to trade in my cheaper $20 set and pay the difference for the better set $43. Wouldn't it be nice if the wires were actually the correct length?? I must have had at least 2-3" to much on about 6 of the wires. I was able to route them around evenly through the holders to make it look good, but dang, I wish they would cut them the right length.
Took about 2 hrs, but I also changed out some wireloom and clothtape to keep everything out of harms way (heat).
Last thing I have to do is get the transmission filter changed and then the pumpkin fluid changed. That will complete my 90,000 mile tuneup by about 88,000 :p
The only real way to get proper fit is to get the cut-to-fit kind and do it yourself. This really pays off though because you get a super clean install, but it's a bit more work. My next set is going to be this way, and they're getting routed along the valve covers all nice and tight.
Nice work Anthony. Hey, too long is better than too short (aint it always :p ). I have a well known brand of wires (sounds like a chemical used in Chinese food) and the wires are too short for my liking.
Thanks guys :)
This is off the subject, but....
Got 20 miles from home tonight in the minivan with the whole family, slowed down in the last town before mine and heard a strange sound. Well, not too strange, but not one that I really wanted to hear. The rear passenger tire went flat. Popped on the temporary donut and away we went home. It had a small leak on the sidewall near the tread. Going to wal-mart in morning to see what they have to say about it. Messed up the sidewall lettering some when it went down and was still rolling. I'm hoping they will prorate the replacement tire.
Later
