spark plugs afr185's
lxwants12's
506
does anyone know of a spark plug number and gap to run on my afgr 185's sittin on a 347 stroker when i use nitrous??? ill be spraying 75 and then probly 100 shot......and does 10 degrees sound good enough on the timing....its a nx wet kit
Autolite 3926's was what edelbrock specified mine to be, and since i have stock ignition, they said the stock .050 gap - gap depends on your ignition they said - and the plugs you need you should probably call and specify, do NOT use the short threads, the threads on the plug i mentioned is the LENGTH spark plug thread you NEED in aluminum heads - good luck
Paul Perreca
