i have an 86 5.0 bone stock other than offroad h pipe and 40s mufflers.
Ive had other problems with surging idle and such and it led to a bad MAP sensor-the diaphragm inside went bad and couldnt hold vacuum like a new MAP. basically i could suck through like a straw. that helped my idle issue drastically. but now ive notice it stuggles and hesitates at higher rpm (2500+) and dogs when driving up a slight incline and misfires on occasion and also when i shut it down when warmed up, i start it back up and it acts like its cold. i pulled it back in the driveway, numbered each plug wire and pulled the plugs out. each and every one of them were a little wet with a gas/oil mixture, and were completely carbon fouled. Also, i noticed my oil pressure is higher than normal, well, the gas is fouling the oil too. its running way too rich, smells like gas. All new injectors, new fuel pressure regulator, new MAP, new ect, new act, new iac, new tps, newer ign. coil, newer plug wires, plugs were new now fouled, cap and rotor were changed, coolant flushed, basically a fresh tuneup to get rid of old electrical parts as they were all original and age wears elec. parts out. does anyone have any idea? also when it really dogs it, it sounds kinda like two hard plastic containers banging one another (hard to explain). local auto parts store "professional" gave advice i already checked and gave me attitude about checking for codes. i dont have an OBD1 scanner nor can i find one cheaper than 200. any suggestions?
