Well....I am hoping to fab up the following when I get around to hooking up the stereo.
Tweets flush mounted in the corners of the repro dash pad.
Mid mounted in the stock factory speaker location in the center of the dash.
Another set of mids in a custom encloser behind the fiberglass panels in the rear down towards the bottom where the little carpet peice glues on. A second set of tweeters replacing the rear courtesy lights in the fiberglass panels in the FB and then 2 eight or ten inch sub enclosers also mouted in a custom encloser behind the side fiberglass in front of the wheel wells. Amps under the rear seat of course. (I still might do the subs in the trunk depending on how much working space I lose with the rollbar, but I want to keep it as low profile as possible)
