  • 1994 - 1995 Specific Tech
Speaking of System Install...
  • Thread starter Thread starter Adam95GT
  • Start date Start date Dec 7, 2006
Adam95GT
2,564
Burlington, NJ
Dec 7, 2006
  • Dec 7, 2006
Anyone put a set of 8's in place of the back speakers on a vert... im thinking about trying it i gotta see if it will fit... some pics and measurements would be great if anyone has them
badstang123
397
Santa Clarita, CA
Dec 7, 2006
  • Dec 7, 2006
I couldn't tell you since I don't have a vert, but it sounds like a pretty cool idea.
Adam95GT
2,564
Burlington, NJ
Dec 7, 2006
  • Dec 7, 2006
yea... i know you could fit 10's in the probe... but you had to dyna mat it to hell... but its cool cause i got left over... i just gotta measure it... and take the pannels off... have not tried it yet in the vert...
Guero
2,148
Dec 7, 2006
  • Dec 7, 2006
will the top still go all the way down?
reddy351
560
12
38
Columbus, Ohio
Dec 7, 2006
  • Dec 7, 2006
That is funny timing. I have a coupe but I just posted to the autosond part of Stangnet about putting some 6" JL's on the parcel deck and building a fiberglass enclosure under it.
You might try that part of the site.
Adam95GT
2,564
Burlington, NJ
Dec 7, 2006
  • Dec 7, 2006
I dont leave this part of the fourm... its home... lol... The top and whatnot is what im worried about clearence and such...
Guero
2,148
Dec 7, 2006
  • Dec 7, 2006
Wait i misread your question... I thought you wanted to put them where the top goes into
Adam95GT
2,564
Burlington, NJ
Dec 7, 2006
  • Dec 7, 2006
i wanna make the hole for the stock 5 1/4 bigger to fit 8'' subs... im pretty sure i can cut it to fit 6 and 1/2's would take some work... but im willing to try it... just want to make sure i have the depth i need
Zero Signal
2,633
Tucson, AZ
Dec 7, 2006
  • Dec 7, 2006
I have 6.5's in the rear mounted to a 3/4" MDF baffle board under the dash. If you do the same setup but recess the baffle face an inch or so, you can mount the 8s without cutting anything and you would have a really nice solid baffle to keep them nice and dead.
EDIT: I just realized you said vert. I'm useless now.
Adam95GT
2,564
Burlington, NJ
Dec 7, 2006
#10
  • Dec 7, 2006
  • #10
LOL i know... was a good idea i got the wood... i wonder what the clearence is between the speaker and the plastic pannel... i might just be able to build up the stock location to create clearence.... might work with 6.5's but 8's on an amp might pound the plastic... lol
Adam95GT
2,564
Burlington, NJ
Dec 7, 2006
#11
  • Dec 7, 2006
  • #11
http://cgi.ebay.com/94-8-ROCKFORD-F...tcZphotoQQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Where does that fit... i assume in the trunk.. wish i could find one to fit a vert...
Adam95GT
2,564
Burlington, NJ
Dec 7, 2006
#12
  • Dec 7, 2006
  • #12
im thinking about trading in my dual loaded box at a trade post for a small single JL or Eclipse Sub... i think im passed the huge bass stage... lol
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Dec 8, 2006
#13
  • Dec 8, 2006
  • #13
The rear speakers are in the b pillar on the vert so the top has no affect. If depth is a problem, you could cut a hole in the plastic panel and mount the speaker to that instead of the metal frame that the factory 6x8 is mounted to.
You would likely have to fab a stand off plate to clear the frame and contour to the plastic curves but it should work.
Once you get everything done and the speaker mounted, I would use some expanding rivets instead of screws, JMO.
Scott
Radio, Speaker Upgrades
  • TripleYellow
  • Apr 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 24, 2026
TripleYellow
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
P
Air Fuel ratio bung location.
  • Praetorious
  • Feb 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2026
2010 V6 Sees differently than GT?
  • 6t9Mach1
  • Mar 31, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Apr 1, 2026
6t9Mach1
