Spec clutch
Bullitt03
196
FT Lewis,WA
If you guys have one maybe you can answer a question for me.
I have a 03GT with a stage 1 in it and every time i run hard from a stop i can smell the clutch is this normal for a spec clutch and it only has about 2000 miles on it
Thanks
Dean
Thanks
Dean
I'm having the same problem with mine as well. Doing a burnout to warm to the DR's leaves some serious clutch odor and sometimes it doesnt grab... :shrug:
Ive got same clutch in my 88 GT, it smelled like clutch for about the first 1500 miles, and i tried to break it in as easy as i could for the first about 600 miles. The smell went away on my car. I got it the most in reverse i had a steep driveway. I think you may need a stronger clutch, try a stage 2. Your car has the max hp/torque rating on the clutch almost stock. 2000 miles you shoulkd not smell clutch anymore??
On the spec website it says 420 torque capacity i have no where near that N/A so i don't know but the smell has gone away so far after a few hard runs today so i maybe it will last another 3 months till i deploy
Thanks for your guys input
Dean
My stage 1 installed last September (maybe 5k ago) still smells on a steep hill start or a if I rode the cluth a little bit. The clutch grabs hard as my best dyno run ever was using the Spec clutch. I probably would not put another spec clutch in next time, but I was unhappy with the lift of my stock clutch as well.
