I have an 88 5.0. What would be a good cam to run in this motor. I have an aod with 4:10 gears and a 2600 stall converter. I am not looking for an extreme profile cam just one to compliment this motor.
You could always retard the stock cam 4* and put some 1.7 rockers on too.... makes a nice improvement and wont give the SD any problems.
Otherwise you could run the E cam, and most likely a B cam as well. I ran the F cam in my 88GT with SD, it idled pretty good with some timing and FP adjustments. Ran good too
the fms alphabet cams aren't that great with the sd, sometimes they run/idle well sometimes they don't. crane 2020 an 2030 are sd, so are crower 15510 am 15511. but mrx is right 1.7's do help. i had them on my aod sd car with a edelbrock intake an 65 tb an it ran pretty strong. if you're runnin the stock heads, change those first or at the same time.
