speed density cam?
icemetalstang
77
I have an 88 5.0. What would be a good cam to run in this motor. I have an aod with 4:10 gears and a 2600 stall converter. I am not looking for an extreme profile cam just one to compliment this motor.
You could always retard the stock cam 4* and put some 1.7 rockers on too.... makes a nice improvement and wont give the SD any problems.
Otherwise you could run the E cam, and most likely a B cam as well. I ran the F cam in my 88GT with SD, it idled pretty good with some timing and FP adjustments. Ran good too :)
the fms alphabet cams aren't that great with the sd, sometimes they run/idle well sometimes they don't. crane 2020 an 2030 are sd, so are crower 15510 am 15511. but mrx is right 1.7's do help. i had them on my aod sd car with a edelbrock intake an 65 tb an it ran pretty strong. if you're runnin the stock heads, change those first or at the same time.
