aight guys i had posted that my car was off on the speedometer off by like 10 or so mph. well today i jacked it up and did a 1 wheel rotation and counted the times the drive shaft turned 4 and a little over well i removed the speedo cable to remove the gear thing and its orange i checked on here and orange and has 20teeth is for a 3.08 gears so i will need to get a 23 white tooth one correct?
more info my car is a AOD and at first i was getting 3 and almost 3/4 turns but now im getting 4 and a little over turns. removing the orange tooth thing and turning the wheel 1 whole turn again should be the same correct?
