  • 1994 - 1995 Specific Tech
speed o gear
  • Thread starter Thread starter Billy8380
  • Start date Start date Mar 5, 2008
1 of 2 Next Last
Billy8380
68
  • Mar 5, 2008
aode
black 23 or
white 23
or either one of them? just wondering b/c from pics they were different size
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Mar 5, 2008
  • Mar 5, 2008
Looks like you'd want the white gear, but it sounds like it's a Jeep part. Check out this post from 5.0 Tech:
http://forums.stangnet.com/showpost.php?p=6255710&postcount=1
Billy8380
68
  • Mar 5, 2008
Yeah just trying to figure it out, seen that alot of people running the white gear in aode but according to steeda it calls for the black one. just wondering? looks like the stem is longer on the black ine just wondering if anyone was using the black one
Dino Dino Bambino
1,672
89
79
Cyprus
Mar 5, 2008
  • Mar 5, 2008
No. The white gear is for manual tranny vehicles. For the AODE you need the black speedo gear and that's the one I have.
Dan95-5.0
1,110
Manitoba, Canada
Sep 7, 2009
  • Sep 7, 2009
ok i'm stumped here.
had 3.27's with a AODE and switched to 3.73's a while ago but never switched out the gear.
which gear do i need? i keep hearing white.
Dino Dino Bambino
1,672
89
79
Cyprus
Sep 7, 2009
  • Sep 7, 2009
Read my last post.
toyman
1,944
54
79
Vernon BC
Sep 7, 2009
  • Sep 7, 2009
Wrong, wrong, wrong.
With the AODE and 3:73 gears you need a 21 tooth driven gear and it's purple. The drive gear with the AODE is a 7 tooth gear. The 21 tooth driven gear will be 100% accurate. The gear you pull will be a tan 19 tooth gear with 3:27 differential.
Dan95-5.0
1,110
Manitoba, Canada
Sep 7, 2009
  • Sep 7, 2009
thank you. nice setup you got there by the way
Dino Dino Bambino
1,672
89
79
Cyprus
Sep 8, 2009
  • Sep 8, 2009
Not all AODE's have a 7-tooth drivegear. My original '95 AODE had an 8-tooth drivegear with an 18-tooth speedo gear and a 2.73 rear end. A black 23-tooth speedo gear corrected my speedo to a 6% overread after I swapped in the 3.73. My current 4R70W has a 7-tooth drivegear and with the purple 21-tooth speedo gear, my speedo is dead on accurate.
If your original rear end was a 2.73, your AODE will have an 8-tooth drivegear and an 18-tooth speedo gear. If it was a 3.27, your AODE will have a 7-tooth drivegear and a 19-tooth speedo gear.
mjsbullitt
#10
  • Sep 8, 2009
  • #10
while were on the subject....i have 3.73's and a manual, but i heard tire size also figures into the equation also (i have 18's). also, is it possible to just have it electronically recalibrated at a shop, although im not sure if many shops even do that, im in the southeast mass area, would Dez tuning do it? and my rpm gauge is off also, (i go by the aftermarket one in the car) how would i go about getting the stock one working correctly.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Sep 8, 2009
#11
  • Sep 8, 2009
  • #11
This is the best reference I have found for looking up speedogears.
TCI - TECHNICAL INFORMATION: Speedometer Gears
Kurt
Dan95-5.0
1,110
Manitoba, Canada
Sep 8, 2009
#12
  • Sep 8, 2009
  • #12
why ford, WHY!?!?!?!?!?!?!
TrueBlue95GT
966
Connecticut
Sep 8, 2009
#13
  • Sep 8, 2009
  • #13
Save yourself trouble and hook up a Dallas Mustang Speedcal. Just wire it inline and flip a couple of switches and it corrects your mileage no matter what gearset/transmission you have. Also, you don't have to worry about chewing up speedo gears.
toyman
1,944
54
79
Vernon BC
Sep 8, 2009
#14
  • Sep 8, 2009
  • #14
Point taken but as Dan95 stated that he had the 3:27 gear which as you noted would mean that the AODE had a 7 tooth drive gear. I should have been clearer.
toyman
1,944
54
79
Vernon BC
Sep 8, 2009
#15
  • Sep 8, 2009
  • #15
No you can't do that. You need to add into the circuit an electronic recalibrator for the speedo such as a "speedcal". How far off is the stock tach? Mine is out less than the with of the needle which I would estimate to be close enough for a tach that is marked only in 500 rpm increments.
earleys94gt
1,223
Ashley, Ohio
Sep 8, 2009
#16
  • Sep 8, 2009
  • #16
Here's some more info...
Speedometer Recalibration Gears - '79-'98 Ford Mustang
Dino Dino Bambino
1,672
89
79
Cyprus
Sep 9, 2009
#17
  • Sep 9, 2009
  • #17
No worries. It would be easier if we could get hold of accurate info. about which auto trannies have a 7-tooth drivegear and which ones have an 8-tooth. I don't think the info. on Steeda's site is entirely accurate:
Automatic Transmissions with 7 Tooth Drive Gear
1983-1989 Automatic Transmissions
Automatic Transmissions with 8 Tooth Drive Gear
1990-1998 Automatic Transmissions
Dan95-5.0
1,110
Manitoba, Canada
Sep 9, 2009
#18
  • Sep 9, 2009
  • #18
thats what i've seen everywhere. Very poor info about this on the net. hopefully others will find this thread when they need it.
is this the ford dealer part number? 375-D0OZ-17271-B
my local tranny shop doesnt have one in stock and said to go to the dealer.
toyman
1,944
54
79
Vernon BC
Sep 9, 2009
#19
  • Sep 9, 2009
  • #19
Can't answer about the part number but if you ask by tooth count and color they can give you the correct one. About $15.00.
Dan95-5.0
1,110
Manitoba, Canada
Sep 10, 2009
#20
  • Sep 10, 2009
  • #20
called up by local dealer and they wanted $25 each and you have to buy them in a pack of 2!!!!
found this on ebay after getting some very weird search results, dont ask.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=180354005242&fromMakeTrack=true
1 of 2 Next Last
Engine 95 GT and 95 Cobra sensors and TB gasket
  • Sonic
  • Dec 21, 2025
1994 - 1995 Specific Tech Dec 23, 2025
WhiteCobra95
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
SOLD 1986 Mercury Capri 5.0 5-speed
  • blackmerc
  • Jul 29, 2026
Fox Body Mustangs For Sale (1979-93) Aug 24, 2026
General karthief
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
T
Newbie looking for some info on speedo gears
  • TDM389
  • Nov 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 16, 2025
TDM389
T
