"Speed sensor"?
  • Thread starter Thread starter diablostang
  • Start date Start date Dec 3, 2004
diablostang
425
Raleigh, NC
Dec 3, 2004
  • Dec 3, 2004
I need a new Speedometer cable in my 88 GT, and I was looking at replacements, and it has the option of with or without speed sensor?
http://secure.50resto.com/product1.cfm?SID=1&Product_ID=2195
5.0Droptop
...all those nights we shared, and you're a dude??
Special Agent Mukity-Muck Whats in Charge Round Here
May 15, 2002
1,785
1,130
233
Indiana
Dec 3, 2004
  • Dec 3, 2004
if you have cruise youll need the speed sensor.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Dec 3, 2004
  • Dec 3, 2004
Some cars have a VSS (vehicle speed sensor). If yours is so-equipped, it will have a device that bolts/plugs into the tranny that has a computer harness connection on it; and the speedo cable will plug into the VSS device. If not, your speed cable will go directly into the tranny. So just look underneath at that part of the tranny and you'll see if yours has a VSS or not - then you can order the proper cable.
diablostang
425
Raleigh, NC
Dec 3, 2004
  • Dec 3, 2004
I've got cruise, though it doesn't work
Micheal, is the speed sensor for the cruise? I had a few electrical plugs in my tranny, but I don't remember anything with an major electrical connections...
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 3, 2004
  • Dec 3, 2004
The VSS signal causes the computer to increase the idle speed via the IAB as you slow to a stop. This is how it helps prevent stalling at lights & stop signs.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Dec 3, 2004
  • Dec 3, 2004
jrichker - as an aside - my IAB/ecu does that with no VSS; so I'm not sure what's up with that.
Diablo - if you have a VSS there should be two computer harness connections on the tranny. One is near the front and it's the neutral indicator connector. The other is the VSS - it's on the same side as the neutral switch, but further back on the tranny.
Just crawl underneath (driver's side) with a light. If the speedo cable plugs straight into the tranny, then you don't have a VSS. If there's a device with an electrical connection on it in between the tranny and the speedo cable - that's your VSS.
diablostang
425
Raleigh, NC
Dec 3, 2004
  • Dec 3, 2004
Ok, thanks, I'll check it out
_jb_
808
Michigan, Berrien County
Dec 3, 2004
  • Dec 3, 2004
Maybe that is the reason why my cruise doesn't work! I replaced my speedo cable and there was no VSS. It just went right into the tranny. Awesome, I'll have to check that out tomarrow!
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
  • dan50
  • Jul 18, 2026
dan50
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
Drivetrain Speedometer and odometer stopped working
  • AnthonyA1234
  • Oct 19, 2024
Fox 5.0 Mustang Tech Nov 8, 2024
