Speed Volume Stopped Working
I have an 06 GT and the speed volume function has stopped working. The last thing I did was install a relay for lights, I pulled the radio fuse under the hood to install a fuse tap and I plugged it back in. I didn't loose my presets but the time was wrong and I had to reset the bass and speed volume controls aswell but the speed volume isn't working anymore. Is there another fuse for this? I even went as far as to take the radio out and make sure all the plugs were in tight.
Thanks!
I wonder if it defaults to the off position if there is a power loss. If you haven't already done so, I would resetting the speed vol setting to where you like it set to see if it is actually enabled.
