  • SN95 4.6L Mustang Tech
SpeedCal & Speedo issues
  • Thread starter Thread starter merc123
  • Start date Start date Dec 3, 2008
merc123
420
North GA
Dec 3, 2008
  • Dec 3, 2008
Searching around I think I may have the problem narrowed down, but just in case...
Had the tranny fixed in the stang and it worked for a bit until it broke again. Anyway, I moved the car to a garage and noticed the speedo/mileage wasn't working and my CEL went on.
I'm assuming it has to be the power source, but what else can I look for?
I went from 3.73's back to 3.27's after the rear end went out (think it was tranny related) so the only thing I need to calibrate for is a 295/18" tire.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Dec 3, 2008
  • Dec 3, 2008
Probably knocked it loose. Happened to mine a couple of time.
slayr281
The poster formerly known as slayr420
7,591
18
98
San Diego, California
Dec 3, 2008
  • Dec 3, 2008
Check your fuses. While your manual says that it's the fuse box inside your car underneath the wheel (20 or 30, I don't remember), I found out that mine fuse problem was actually inside the engine bay on the driver's side box. It was a green, want to say big 25. Basically, my speed was all messed up, and I'd stall out at every other stop light. I swapped my fuses, and lost my sound through subs/amps, and I believe my turn signals, but the speed was dead on.
Although, since you swapped your transmission, chances are you're right with it not being connected to the power source, or a bad connection somewhere connecting to the transmission.
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
90 Mustang GT speedo cable issue
  • sublimer6969
  • Feb 11, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2024
limp
New Member with a 1992
  • Clutchfork
  • Oct 18, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 19, 2025
Clutchfork
