Speedo Cable problems i think?
  • Thread starter Thread starter savegoodautonfg
  • Start date Start date Jul 27, 2007
savegoodautonfg
1,085
  • Jul 27, 2007
My speedo needle jumps btwn 20-40 mph then its fine. also theres been a nosie i hear more when the windows are closed. if you put ur head out the window you can barely hear it. My mechanic thinks its coming from the speedo cable behind the cluster. is that possible?
D
daleclough
18
  • Jul 27, 2007
Same issue here, but my bounce is 20-50 and the noise is noticeable inside only.
savegoodautonfg
1,085
  • Jul 27, 2007
Anyone know what it is?
cOULD it be the speedo cable?
Mustang78
486
Aberdeen, WA
Jul 28, 2007
  • Jul 28, 2007
yes most definately the speedo cable and/or the speedometer gear on the end of the cable...a new cable was 22 bucks at schucks a month ago
~Mark~
savegoodautonfg
1,085
  • Jul 28, 2007
Should i mind as well get the new gear too?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 28, 2007
  • Jul 28, 2007
Speedometer cable replacement for 87-93 Mustangs.
Note: All 89-93 cars have a VSS sensor even if they do not have cruse control. The 87-88 only have a VSS sensor if the have cruse control.
Speedo cable housing assembly without cruse control:
The VSS equipped cars have a speedo cable with a different fitting on the transmission end of the cable. It is the fitting on the LH side of the following picture.
Speedo cable housing assembly with cruse control
Inside the car:
1.) Remove the shield around the steering column that covers the ignition switch & turn indicator switch.
2.) You now have access to the two screws that hold the lower part of the cluster housing in place. Remove them and place them in a zip bag.
3.) Use a stubby or an offset Philips screwdriver to remove the two screws on the top of the cluster housing. The screws are up close to the windshield, so they can be hard to get at.
4.) The cluster housing will now slide forward: depending on your particular car, you may or may not have to disconnect the wiring for the headlights, hazard lights, or cluster wiring. All of the wiring uses plastic connectors with plastic spring clips on them. To release the connectors, lift the plastic clips and pull straight back.
5.) The speedo cable is secured in the speedo head by a white plastic clip. Depress the clip or squeeze it and pull the cable out of the speedo head. This can be tricky, but it will come out if you have the white clip depressed enough.
6.) With speedo cable removed from the speedo head, try twisting the cable end with your fingers. If it turns more than 1/4 turn, the cable may either be broken or you have damage at the other end where the cable mates to the VSS sensor or speedo pickup gear in the transmission.
Outside the car, replacing the cable housing assembly. The following steps are necessary only if you plan on replacing the cable & cable housing assembly.
7.) If you are going to the replace the cable housing, the next step is important. Tie a study string or wire to the VSS sensor end of the cable housing. This string or wire is to be used to fish the cable housing back through the maze of wires that is under the dash. If all you are going to do is replace the inner cable, you can omit this step.
8.) Jack up the car, all 4 tires must be off the ground. Place jackstands under the car for safety.
9.) Locate the VSS sensor on the driver’s side of the transmission tailshaft housing. The speedo cable housing will be secured in the VSS sensor with a hairpin clip Do not remove the clip!!!: The hairpin clip stays in place. If you remove it, the odds are that you will not be able to get the cable to stay in place on re-installation. Pull firmly straight back on the cable housing and it will come out. A considerable amount of effort may be required to get the cable out of the VSS sensor, but it will pull out.
10.) Release the cable housing from the clips that secure it to the car body.
Inside the car:
11.) The housing assembly can then be pulled out and the fish string or wire can be removed from the old cable housing and secured to the new one.
12.) The inner cable can be removed by pulling it out of the housing assembly. Watch out for the lubricant so that you don’t get it on the car’s interior.
13.) Lubricate only the lower part of the new cable with speedometer lubricant or graphite. Don’t use too much lubricant, or it will work its way up into the speedo head unit and damage it. Thread the inner cable into the housing, turning it as you go. When you are all the way in with the new cable, it will engage the VSS sensor and stop turning.
14.) Use the fish string or wire to feed the cable housing assembly through the dash wiring and out the cable hole in the firewall.
15.) Secure the cable in the body clips, making sure that the cable isn’t rubbing against the exhaust pipe.
16.) Push the cable housing assembly into the VSS sensor until it snaps in past the hairpin clip.
Inside the car:
17.) Push the cable housing back into the speedo head unit. You should be able to feel the white clip click into place.
18.) Reconnect all the wires & connectors on the speedo head unit.
19.) Re-install the cluster unit in the dash & tighten the 4 screws that hold it in place.
20.) Re-install the cover for the ignition switch & turn signal.
21.) If the car is up on jackstands, start the car, place it in gear & watch the speedo to see if it works OK. If you didn’t jack the car up, take a test drive.
savegoodautonfg
1,085
  • Jul 28, 2007
My mechanic said if i remove the parts of the dash he'll do it for $75 dollars.
should i just have him do it?
glowstang93
20+ Year Stangneter
Feb 9, 2003
853
Illinois
Jul 28, 2007
  • Jul 28, 2007
I didn't do the gear, but I did change the speedo cable. That part is not that big of deal, follow Jr's instructions and you will be fine. Besides, if you get the dash all apart and then can't do it, you could pay the mechanic, but give it a try first. Just remember where and how the cable is routed down to the transmission. I got my cable from Napa and I think it has been hashed out that it is the same on a 5.0 as a 2.3.
One hint though, I busted my knuckles pulling the cable from the transmission. The cable housing came loose from the metal end and my hand hit the bottom of the car. I would suggest using a pair of channel locks to hold onto the cable tip when pulling it from the mount.
I also used some split vacuum hose to cover the cable where it ran right next to the bottom of the car. I thought it might keep it from rubbing through the cable casing.
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
  • dan50
  • Jul 18, 2026
dan50
Fox Help I think my speedometer broke
  • 93CalypsoConvert
  • Dec 21, 2023
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 26, 2023
Boostedpimp
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
