speedo cable squeaking
  • Thread starter Thread starter sgarlic
  • Start date Start date Aug 7, 2005
sgarlic
3,085
Aug 7, 2005
  • Aug 7, 2005
Greetings all. I've noticed within the last month or so, that when I'm driving (with no radio on, etc) I can hear the speedo-cable rotating where it plugs in to the instrument cluster. I'm curious if I can put some sort of grease on the cable myself (if so, what grease is recommended?) or perhaps WD-40 or PB Blaster?
Edit: I see some people recommend White Moly type grease.. any opinions?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 8, 2005
  • Aug 8, 2005
Check with the local auto parts store for some graphite speedo cable lube.
You are supposed to only lube up the bottom half of the cable so that the lube doesn't get in the head unit.
sgarlic
3,085
Aug 9, 2005
  • Aug 9, 2005
Will that stuff work its way up to the top? Since the top where it connects to the cluster is where the squeak comes from..
C
Camman
1,055
Las Vegas, NV
Aug 9, 2005
  • Aug 9, 2005
Yes it will work its way over the whole cable. Also, I have always used lithium, so if you have that handy you can use that
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
Electrical tachometer conversion from 6 to 8 cylinder (will also work for 4 to 6 or 4 to 8 but with different resistor size)
  • extra_stout
  • Oct 8, 2022
6K
1974 - 1978 Mustang II Talk & Tech Jun 9, 2025
extra_stout
V
A 20 year old car, with many faults!
  • Virus101
  • May 4, 2020
  • SN95 4.6L Mustang Tech
3K
SN95 4.6L Mustang Tech May 9, 2020
Cobra262
C
F
Instrument Cluster Flex Circuit Shorted - Repair/replace?
  • fl4
  • Jul 15, 2017
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 6, 2019
TVS
T
Is This A Tv Cable? Shifter Cable? Removed From 1987 5.0 Lx
  • bcmbcmbcm
  • Jun 4, 2016
Fox 5.0 Mustang Tech Jun 4, 2016
mikestang63
