Changing the trans speedo gear means removing the trans and then removing the tailshaft housing. That means disassembling the shifter mechanism.
See
http://www.ttcautomotive.com/English/onlineorder/product.asp to download a FREE service manual for T5 or Tremec 3550
You will need the Adobe Acrobat viewer which is also a free download –
http://www.adobe.com/products/acrobat/readstep2.html
See
http://www.hanlonmotorsports.com/ or
http://www.ddperformance.com for parts
There is another way...
The stock range of speedo gears work correctly with a limited range of tire sizes.
See
http://www.corral.net/tech/gearcalc.html for more help
Check to see if there is a speedometer shop in your area. If there is, ask about the Stewart-Warner speedometer gearbox. I believe it is either a 777 Series Drive Joint Kits and Parts or 666 Series Drive Joint Kits and Parts. It is a small gear box that fits between the speedo pickup gear on the transmission and the speedometer. It has quick change gears that allow you to choose almost any tire size and rear end gear ratio you want. This will allow you to get the accuracy with within 1%-3%. The drawback is that it isn't cheap.
Please excuse the typo (their's, not mine) in the following picture - it should read
Custom ratio adapters, not Custom radio adapters.
See
http://www.gaugeguys.com/ratioadapt.htm for more info.
