Ok so my 95 t-5 mustang has 3.73 gears and I'm trying to correct the speedo. Upon searching Some say, 23 tooth some say 21. I hear that you have to change the gear in the tail shaft to get most accurate and that the trans needs to be pulled to do so or makes it easier to do so and that is not gonna happen. Latemodel has this kit http://www.latemodelrestoration.com...-95-Mustang-Speedo-Gear-Kit-T5-With-373-Gears that has both drive and driven gear ones yellow and the other is red, (I dont know which is which) they also have different colored gears of the same tooth count, ie: a red 21 tooth and a purple 21 tooth as well as a black 23 and a white 23. So which one do you use and how well will it fit if you dont change the gear in tail shaft? Also I hear since the closest gear is a jeep product it will wear out, how long will it last before it does? Oh and IU also read on a post where some guy was told to uses a speed cal and was flammed for askin what one is. Well I know what one is but will it even work on a 95 since its not an electronic speedo??
Please help
mike
Please help
mike
