Does anyone know how to install the white 23 tooth speedometer gear? I heard it only takes like 15 minutes to install and its easy to do but I have no idea where to even begin. Anyone have instructions or has installed it before? Thanks.
fgtmustang95 said:Thanks man. Ill give it a shot tomorrow. It sounds easy but I bet your right about getting under the car.
Id rather have a speedo that is 5-6 mles off. But if I keep chewing up gears Ill keep that in mind.go-stang5.0 said:You basically have to:
1. Drain the tranny
2. Pull the DS
3. Remove trans cross member
4. Remove shiftboot and shifter
5. Use a punch to remove a dowl pin (inside the tranny right below the shifter)
6. Unbolt the tailshaft housing and remove it.
7. replace the speedo drive gear (slide old one off and new one on) and driven gear.
Now just reverse the steps. You dont have to pull the tranny off the car or anything.
