  • 1994 - 1995 Specific Tech
speedo gear...please help
  • Thread starter Thread starter allenpark94gt
  • Start date Start date Jul 16, 2004
A
allenpark94gt
196
allen park
Jul 16, 2004
  • Jul 16, 2004
getting the gears installed monday...i've gone to a few trans. shops around here looking for a 23 tooth speedo gear....a mechanic told me that if i dont change the tail-shaft gear i'll ruin my car because that and the speedo gear wont be the same...is this true?...also he said it will be way farther off because my car is a t-5 rather than an aod....is this true?...also anyone know where to order this 23 tooth gear from?
9
95cobra50
167
  • Jul 16, 2004
http://www.steeda.com/store/-catalog/speedometer.htm
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Jul 17, 2004
  • Jul 17, 2004
ruin your car how? You can change the tail shaft gear to make it more accurate,or you can buy a speedcal and be pretty much dead on.
What would make it more off than the other would? As far as I know it should read about the same.
Steeda sells them.
GTPhreak
5,505
Rowlett, TEXAS
Jul 17, 2004
  • Jul 17, 2004
what ratio gears are you getting put in?
A
allenpark94gt
196
allen park
Jul 17, 2004
  • Jul 17, 2004
AznStanger3v
2,026
Northern VA
Jul 17, 2004
  • Jul 17, 2004
i just go to my local ford dealership to get any steeda parts. steeda.com has them too. 15 bucks i believe. dont pay the guy for the labor on that gear. youll be kicking yourself in the ass when you figure out how easy it is to do it
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jul 17, 2004
  • Jul 17, 2004
Yeah, it literally took under 2 minutes to remove/install the speedo gear once the car was jacked up.
You won't find the 23 tooth speedo at a speedo shop. You have to go to Ford or Chrysler. They will tell you that they only sell up to 21 tooth speedo gears (in the ford section). Then tell them you are doing a gear swap. They will look in the gear swap section, and find the right speedo gear. It's actually a Chrysler part, so you might as well get it there. Ford buys it from Chrysler. It's $18 from Ford.
BTW, the speedo gear is the "smaller" gear. They might ask you that. It's pretty small.
Or, if you have time, you can get it from www.50resto.com for $10.
Scott
GTPhreak
5,505
Rowlett, TEXAS
Jul 17, 2004
  • Jul 17, 2004
23 tooth speedo gear will get you accurate to 3.55 gears, unless you also feel like tearing into the transmission to change the drive gear. it may be more expensive, but if you want it to be 100% accurate, get a speed cal
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
