You didn't answer some questions - is it already hooked up and inaccurate, or is it not hooked up at all? Do you know if the Stang's speedo cable/gear is compatible with the C4? Those tires are about 24.4" tall (if you're correct about the size) - compared with about 25.7" tall for most of the HO Stangs out there. That makes your 3.73 gears about like a 3.89 gear in a Stang with stock 16" tires. But here's the challenge - the C4, I believe, is a 3 speed tranny with a 1:1 final drive (boy is that thing gonna be a revver on the highway!!!). The AOD's and T-5's have a top gear ratio of about .68 or .63:1. So your top gear is about the same ratio as if you drove along in an AOD in 3rd gear, or a T-5 in 4th gear. Consequently, finding the right gears to make an accurate speedo is a tough task. It will likely require changing the drive gear inside the C4 - which is usually a major pain (on the T-5 it is) -- that's why I said following jrichker's advice about getting a speedo box to correct the error may be the best way to go.
