speedo gear
ponypowa2
228
Destin, FL
Hey all I am having 3.73's installed very shortly and was wondering what I need to do to keep the speedometer accurate. Do I need a speedo drive gear, or just a speedo gear? I appreciate any help thanks.
To get the speedometer to be VERY close, you need to pull the tailshaft off of the trans and replace the 8-tooth gear with a yellow 7-tooth Fox body gear. After you change that, you can use a 21-tooth speedometer gear, and the speedometer should read accurately up until about 70 MPH. I've found that mine reads either fast or slow (can't remember) 1 MPH at 70 and about 3 at 100.
Joe
I need to get mine calibrated with new speedo gears.
Right now, I have a piece of paper on my instrument panel that says to go 10 read 12 and so on. I just worked out every 10 mile per hour speed and what it will actually read on my speedometer.
EDIT: Here is a ROUGH conversion with 3.73's from 3.08's.
speed reading:12__24__36__48__60__72__84__96__108__120
_actual speed:10__20__30__40__50__60__70__80__90___100
:D
